Fuel pump Q's?
Hi peeps,
I must replace my fuel pump,assy is all right,the motor is not working anymore.
What should I do,replace only the motor or full assembly,aftermarket,performance or OEM?
Plans to keep it stock for the moment,but the tank is out right now,should I get a performance pump now,so when the time comes to MOD the engine it's already their...
Please help
Please help
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
OK,I'v got my mind set on the Racetronix pump,but before getting the Racetronix,has anyone used to TRE Performance fuel pump?And is the Walbro unit that noisy?
Just a heads up my tre performance 255 pump **** the bed several months ago, it would be slow to build pressure after heavy use. The pump I had did this several weeks after I had installed it. I toubleshooted the rest of my fuel setup till I finally gave in and replaced with a walbro unit. In my case the pressure build was signifigantly faster and I have had no problems since. Just my experience though I have heard of people not having problems. Good Luck.
