Car won't start, or even crank...
I sure hope you checked voltage with the starter disconnected and someone bumping the ignition to make sure you are getting proper voltage because if you are then the idiot that tested your starter needs to be fired. That is assuming your terminals are in good repair
check the gauge cluster fuse, if the dash goes dead when you try to start and the battery and alternator are good but the whole car still dies when you try to crank it, it might be that. Its very hard to find when its the simplest stupidest thing in the world. My car was down like 3 days and it was a retarded little fuse lol man was i pissed
good luck either way
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
