Lower Compression
the block and internals are all stock.
I know that i will need subframe connectors, torque bar, and possibly wider rear tires. of course on top of internals.
as it sits it should be around 450whp and 500+torque. that's just what ls1 motorsports wrote up about the kit.
Using thicker head gaskets or heads with larger combustion chambers works too.
Also, you can lower dynamic compression with a cam that has later intake valve timing. The other methods lower both static and dynamic.
