shreveport/bossier hang out!
#6281
By the way, I know you work at the feed store or something and shooting the breeze about cars may be all you have to do, but I run a business and don't have the time or patience to listen to you at work.
#6283
UPS never granted any credit, which I would've given to you just to be done with the deal. My wife pulled all of the pics which she took while before and after painting the intake and there was no crack anywhere. And no, after talking about this for weeks I wrote this deal off as a learning experience and will never sell high dollar parts on here again. AS for a post to buy an upper, I told you I'd help you find a deal if possible. Trying to help you was getting me nowhere so I washed my hands of it. You or your buddies dropping the intake is not my fault. You seem to only remember what you want to, but you told me there was no damage to the box and the intake was packed very well. My pics show it in perfect shape so where did the problem occur?????
Hmm, you never got a credit so you didnt do any follow up? Funny read your last PM you sent me. Here I provided it for you just incase you deleted it.
I would think if you didnt get a credit you would follow up with UPS and get my money owned to me correct?????
![](http://i74.photobucket.com/albums/i277/jcmorton22/clint.jpg)
#6286
this is to any body who likes to here only one side off the story. i am refering to taws6m6 your drive drive shaft was not in the right way because the dumb @ss who put it in put the wrong one in... it was flopping in the saddles.. not to mention the car ran like $hit, would not stay running and is very obnoxiously loud and if youcant under stand that ,, that means it sounds like $hit. and for the people that only get 3 to 400 miles on a trans 9 times out of 10 it is due to 1 or 2 things, 1-----if your trans was broken and not burnd up then chances are you have a lot of fine metal in your cooler and you CAN NOT CAN NOT get it all out.. and if you dont think that then cut your cooler open and look what it is made like.. it looks like an sos pad,,, . the metal gets trapped in and when you rebuild a trans and put it in , and put new trans fluid in it starts to clean more due to the fluid and heat ,, and if you dont know what trans fluid is like i will tell you beings you dont know any thing any way..... trans fluid is a high detergent fluid , as it heats up it starts to brake lose more of the metal trapped in the cooler,, which means what???? wont to guess or do i need to tell you?? i will tell you any way. it gets back in your trans and starts @@ucking thing up again. which means if you install trans and dont clean or replace your radiator it WILL @uck up again.
now as far as the bushing and seal replacement it dont take no time at all to do, but when some body has already replaced it and it still leak then some thing is causing that beacuse those dont just leak .
just remember people there is always 2 sides so dont just go and think bad of somebody because of what you heard, because it could be a croc of $hit, especially to those who dont know any thing about working on car .
#6287
and for the 2nd thing that cause a tran not to last very long is not knowing how to install them......other then that the parts that are put in, they are all moving parts and any thing can happen at any time,, no body can tell you when your planet is going to go out or tell you when your sun gear or you input drum or when your sun gear or any thing is going to go out.
thats all i am going to say about that or i will have to start charging you for know what i know,, thats why i do what i do and you do what you do.
have a great day
have a great day
#6290
have a great day
have a great day
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
#6291
Its also funny that I have never seen a manual trans with a trans cooler. Or planetaries or a sun gear or anything else he quoted
I'm surprised you didn't tell him to check his blinker fluid, or his muffler bearings
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#6292
have a great day
have a great day
shaft immediately after it was replaced I wanted it replaced, regardless of what you thought. Everyone said patc was shady, and now I guess we can all see it firsthand. I am sure after people read this they will all be begging to bring their cars there, if anything you only hurt your cause getting on here and talking ****. Now, good day to you sir.
#6293
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The guy I'm talking about BOUGHT a new trans from PATC and it took a **** almost as soon as PATC finished putting it in. So that takes both of your excuses out. Lets just face it, PATC is a SHITTY company!
#6294
01ssreda4 you cant read very well can you ? Thats ok .... Ididnt say that a standard had planets and sun gears. If you will re read my post ,,, but do it slow so you can under stand it.. And for all those who think they are so @ucking smart why dont you do your own work and take every body else out of the plroblem....or can you most likely not.
#6295
Rockstar
By the way, maybe if you worked on your ******* grammar we could understand what you're trying to convey to us.
#6296
You were talking about transmissions. TAWS6M6 has a six speed not an auto. I know quite a bit about his car and several others in the area. I also know for a fact that he is plenty knowledgeable about f bodies. Somebody played him for some dipshit that doesn't get his hands dirty and that just plain isn't the case. You don't know any of us or what we do in our spare time. Go to the corvette forums and talk ****. They are the ignorant ******* who don't know **** about their own cars.
#6297
Tough Mudder
I'm still curious how a stock driveshaft doesn't fit a stock ten bolt.
Unlike some of the others, this is the first I've heard about PATC, either positive or negative. I have to say that this was not a very positive first impression.
#6298
Tough Mudder
If I owned a shop I would do several things differently. The main one that sticks out is that I wouldn't respond in a public forum with insults, or especially profanity. I curse a good bit during day to day personal life. When it comes to business, it's time to leave that language behind. Text doesn't go away. What I say aloud, as long as I'm not recorded, leaves no record.
You have most likely lost TAM6WS6's business forever. That's not great, but not horrible. What's happening now is that you are confirming his statements by coming off as a jerk.
This could cause other readers to reconsider coming to your business. This IS a big deal. LOTS of people frequent this site, and this thread is pretty popular.
Also, now once anyone who is NOT familiar with PATC does a search, he or she will find this conversation.
The majority of this is common sense.
#6300
firstof all if you will go back and read you WILL find that i did not use ANY profanity
2nd of all i dont own this company. and asfar as any thing being recorded, ever letter you type and post is recorded,, even if you did not type it and some body else used your profile it still leaves you at fault. because it is illegal to type any profanity on any web site.
and onther thing who said ant thing about patc responding to this. just because i responded dont mean anything.
and as far as corvettes i will put one against any one you. that has a trans in from me.
