New Orleans Put the greasy talk here...PiMp
shreveport/bossier hang out!
Old 02-23-2011, 07:58 PM
  #9821
BlueThunder2's Avatar
Correct. Just get that pump in there and you will be fine.
Old 02-23-2011, 10:12 PM
  #9822
Cold06's Avatar
Well I'm going with a ported fast 92 and a NW tb now I should see what 20-40 rwhp over the hp you quoted me?
Old 02-23-2011, 10:17 PM
  #9823
brett walker's Avatar
Damn your list sounds nice, all I have so far is Hooker super comp LT's, Hooker Ory, 3'' exhaust band clamps, Motive 4.10's, Thunder racing Trex cam, and pushrods so far. My needs are dual valve springs Pac or Patriot doesn't matter, Ls6 intake, Lm1 resonator, Pro 5.0 shifter and Wet kit
Old 02-23-2011, 10:26 PM
  #9824
Cold06's Avatar
I can get you a good price on a wet kit Chad Davis here in town sells cold fuson kits for 300 and purge kit is 80 I think, I have a HSW 78mm plate with nozzles and tb brackets that I cant run now I will sell you. Im getting a 92mm plate from Chad. He cant get 78mm plates.
Old 02-23-2011, 10:43 PM
  #9825
hmmmmm
Old 02-23-2011, 10:51 PM
  #9826
Cold06's Avatar
Lmao ***** getting real!
Old 02-23-2011, 10:53 PM
  #9827
Cold06's Avatar
Ivory you need a s/n lol
Old 02-23-2011, 11:09 PM
  #9828
01ssreda4's Avatar
And this ^^ hahaha! Todd you said I wouldnt need injectors right now correct?
You'll be alright to run your stockers for a while. I personally would put injectors in my budget for a cam and ported heads combo. Ask some of the guys who have run out of fuel on the dyno with stock injectors. FIC will rebuild, rejet, and flow match your stockers to whatever specs you want.
  #9829
Yea i'll have to get with you on tha wet kit when the time comes, but does Todd do tunning ? And since your going with the fast setup that means Ls6 intake for sale right ??? lol
Old 02-23-2011, 11:11 PM
  #9830
Dnt mean to be a noob but wats a s/n ?
Old 02-23-2011, 11:16 PM
  #9831
Cold06's Avatar
I really don't have a budget lol its what I dam send and not have the wife got midevil on my ***
  #9832
Cold06's Avatar
Plus I'm a cheap bastard
Old 02-23-2011, 11:30 PM
  #9833
01ssreda4's Avatar
If you are talking about spraying, fueling is not an area to go cheap on. Go lean once and say bye bye
Old 02-23-2011, 11:52 PM
  #9834
Cold06's Avatar
When you run a wet kit it pulls fuel off the fuel rail and mixes with the nitrous in the nozzle or in my case plate, so reading plugs and making a quick jet change your good to go. If I had a dry kit I would need larger injectors to make up the fuel in the chamber. I will have a safety switch on the fuel and nitrous to shut the system down if one or both drop psi to save the motor!
Old 02-23-2011, 11:55 PM
  #9835
Cold06's Avatar
Yes Todd is the best around hands down!! ls6is going to bud with my ported stock tb, hes getting the fast 92 from a buddy down south and ill give him a lil extra $$ on top to make it good plus he sold it to me so hes got dibs! Yea just hit me up when you want to get a kit I cant say I woulnt have the plate sold by then...
Old 02-23-2011, 11:56 PM
  #9836
Cold06's Avatar
Screen Name lol make a new one haha!
Old 02-24-2011, 12:05 AM
  #9837
01ssreda4's Avatar
Yea that's where the pump and a wet kit comes in, injectors only matter on a dry kit
Yeah, I understand how a wet kit works. The problem is, with a cam and ported heads you will be maxing out stock injectors. Some have better luck, some have worse. Going slightly lean NA may not be that big of a deal, but imagine if you are spraying.....the consequences could be a lot worse.
Old 02-24-2011, 12:08 AM
  #9838
Cold06's Avatar
Yea but I could up a fuel jet and make up some fuel while spraying.
Old 02-24-2011, 12:09 AM
  #9839
Cold06's Avatar
I really running a baby cam its just makes power gobs of power below the curve!
Old 02-24-2011, 12:12 AM
  #9840
01ssreda4's Avatar
Thats cool. Just check your duty cycle on your injectors at WOT. You aren't "supposed" to run them over 80%. However, Im sure tons of people have in the past. Just something to think about.
Quick Reply: shreveport/bossier hang out!
