shreveport/bossier hang out!
My brothers parts are pouring in this week, LS6 intake, ASA Cam, Pacesetter ceramic headers, TSP y-pipe, HID's with clear corners, new AC compressor, and the Todd recommended 4 in. single hideaway dump catback, and the most important part a blue thunder tune
what do yall use to hold the lifters during the cam swap?
Attatched is some pics. As you can see, I can unplug the wires from the switch piece, but cant get that switch assembly out, at least properly. When I tried taking the the lock switch out from top it broke the other rocker side that was not broken. Right now, only one side is snapped on the driver window switch. I don't have replacements yet, but I was figuring to swap the button from the passenger door to the driver door to let me use the window until I order some replacements.
There is gonna be some release tabs around the perimeter of each of the switch boxes that you will likely have to release. Notice the one box has the hump running down it. You will probably need to insert a small flat blade screwdriver in there to release it. try shining a flashlight in to see if you can see what needs to be pressed on.
