shreveport/bossier hang out!
dan you dont have to work the air show? CE will be working smh. I dropped the trans off at smoke dog and kens today looking foward to getting it back in the car, also changing the exhaust. turns out it was the int. sprag. oh yeah i seen a black 6 speed camaro this morning on the way to work getting on 49 from burtkouns car sounded good
Gonna try and help Josh out with his 42 pound injector install. If anyone with HPTuners experience sees something wrong please point it out. I'm still a newbie at this.
Under Fuel>General then the center Injector Control column the first block is Offest vs. Volts. vs. VAC, plug these numbers in your table:
Labels 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
4.5 7.7770512648 7.8228312648 7.8533512648 7.8991212648 7.9296412648 7.9906812648 8.0517112648 8.1127512648 8.1737912648 8.2195612648 8.2653412648 8.3111212648 8.3568912648 8.4331912648 8.4942312648 8.5705212648 8.6315612648
5 6.7134513611 6.7592313611 6.7897513611 6.8355213611 6.8660413611 6.9270813611 6.9881113611 7.0491513611 7.1101913611 7.1559613611 7.2017413611 7.2475213611 7.2932913611 7.3695913611 7.4306313611 7.5069213611 7.5679613611
5.5 5.7465423577 5.7923223577 5.8228423577 5.8686123577 5.8991323577 5.9601723577 6.0212023577 6.0822423577 6.1432823577 6.1890523577 6.2348323577 6.2806123577 6.3263823577 6.4026823577 6.4637223577 6.5400123577 6.6010523577
6 4.8675341728 4.9133141728 4.9438341728 4.9896141728 5.0201241728 5.0811641728 5.1422041728 5.2032341728 5.2642741728 5.3100541728 5.3558241728 5.4016041728 5.4473841728 5.5236741728 5.5847141728 5.6610041728 5.7220441728
6.5 4.0684358229 4.0989558229 4.1142158229 4.1447258229 4.1752458229 4.2210258229 4.2515458229 4.2973158229 4.3430958229 4.3736158229 4.4041358229 4.4346558229 4.4651658229 4.5109458229 4.5414658229 4.5872458229 4.6330158229
7 3.269337473 3.299847473 3.315107473 3.330367473 3.345627473 3.360887473 3.391407473 3.406667473 3.421927473 3.437177473 3.467697473 3.482957473 3.498217473 3.513477473 3.513477473 3.528737473 3.543997473
7.5 2.4702391231 2.4854891231 2.5007491231 2.5160091231 2.5312691231 2.5465291231 2.5617891231 2.5770491231 2.5923091231 2.6075691231 2.6228291231 2.6380791231 2.6533391231 2.6533391231 2.6685991231 2.6685991231 2.6838591231
8 1.6711407732 1.6864007732 1.7016607732 1.7169107732 1.7321707732 1.7474307732 1.7474307732 1.7626907732 1.7779507732 1.7779507732 1.7932107732 1.8084707732 1.8084707732 1.8237307732 1.8237307732 1.8389907732 1.8389907732
8.5 1.4561479 1.4714079 1.4714079 1.4866679 1.5019279 1.5171879 1.5171879 1.5324479 1.5476979 1.5476979 1.5476979 1.5476979 1.5629579 1.5629579 1.5782179 1.5782179 1.5934779
9 1.2411550268 1.2411550268 1.2564150268 1.2564150268 1.2716750268 1.2869350268 1.2869350268 1.3021950268 1.3174550268 1.3021950268 1.3021950268 1.3021950268 1.3021950268 1.3021950268 1.3174550268 1.3174550268 1.3327150268
9.5 1.0261621535 1.0414221535 1.0414221535 1.0414221535 1.0414221535 1.0566821535 1.0719421535 1.0719421535 1.0872021535 1.0872021535 1.0872021535 1.0872021535 1.0872021535 1.0872021535 1.1024621535 1.1024621535 1.1024621535
10 0.8111692803 0.8264292803 0.8264292803 0.8264292803 0.8264292803 0.8416892803 0.8416892803 0.8569492803 0.8569492803 0.8569492803 0.8722092803 0.8722092803 0.8722092803 0.8722092803 0.8874692803 0.8874692803 0.8874692803
10.5 0.6861026411 0.7013626411 0.7013626411 0.7013626411 0.7013626411 0.7166126411 0.7318726411 0.7318726411 0.7166126411 0.7471326411 0.7471326411 0.7471326411 0.7318726411 0.7623926411 0.7623926411 0.7623926411 0.7471326411
11 0.5610360018 0.5762960018 0.5915560018 0.5915560018 0.5762960018 0.6068160018 0.6068160018 0.6220760018 0.5762960018 0.6220760018 0.6220760018 0.6220760018 0.5915560018 0.6373360018 0.6373360018 0.6373360018 0.6068160018
11.5 0.463638973 0.478898973 0.478898973 0.494148973 0.478898973 0.494148973 0.509408973 0.509408973 0.494148973 0.524668973 0.524668973 0.524668973 0.494148973 0.524668973 0.524668973 0.524668973 0.509408973
12 0.3662419442 0.3662419442 0.3815019442 0.3815019442 0.3815019442 0.3967619442 0.3967619442 0.4120219442 0.4120219442 0.4120219442 0.4120219442 0.4120219442 0.4120219442 0.4120219442 0.4120219442 0.4120219442 0.4120219442
12.5 0.2926407804 0.3078907804 0.3078907804 0.3231507804 0.3231507804 0.3231507804 0.3384107804 0.3384107804 0.3536707804 0.3384107804 0.3384107804 0.3384107804 0.3384107804 0.3384107804 0.3384107804 0.3384107804 0.3384107804
13 0.2190396166 0.2342996166 0.2495596166 0.2495596166 0.2495596166 0.2648196166 0.2648196166 0.2648196166 0.2800796166 0.2648196166 0.2648196166 0.2648196166 0.2648196166 0.2648196166 0.2648196166 0.2648196166 0.2648196166
13.5 0.1548461204 0.1853661204 0.1853661204 0.1853661204 0.2006261204 0.2006261204 0.2006261204 0.2158861204 0.2158861204 0.2158861204 0.2006261204 0.2006261204 0.2006261204 0.2006261204 0.2006261204 0.2006261204 0.2006261204
14 0.0906526241 0.1211726241 0.1211726241 0.1364226241 0.1364226241 0.1364226241 0.1516826241 0.1516826241 0.1516826241 0.1516826241 0.1364226241 0.1364226241 0.1364226241 0.1364226241 0.1364226241 0.1364226241 0.1364226241
14.5 0.0748809462 0.0901409462 0.1054009462 0.1054009462 0.1206609462 0.1206609462 0.1206609462 0.1206609462 0.1206609462 0.1206609462 0.1054009462 0.1054009462 0.1054009462 0.1054009462 0.1054009462 0.1054009462 0.1054009462
15 0.0591092682 0.0743692682 0.0743692682 0.0896292682 0.0896292682 0.0896292682 0.0896292682 0.0896292682 0.0896292682 0.0896292682 0.0743692682 0.0743692682 0.0743692682 0.0743692682 0.0743692682 0.0743692682 0.0743692682
15.5 0.0543777648 0.0696377648 0.0848877648 0.0848877648 0.1001477648 0.1001477648 0.1001477648 0.1001477648 0.1001477648 0.0848877648 0.0848877648 0.0848877648 0.0696377648 0.0696377648 0.0696377648 0.0696377648 0.0696377648
16 0.0529583138 0.0834783138 0.0834783138 0.0987383138 0.1139983138 0.0987383138 0.0987383138 0.0987383138 0.0987383138 0.0987383138 0.0987383138 0.0834783138 0.0834783138 0.0834783138 0.0834783138 0.0834783138 0.0834783138
16.5 0.0525324785 0.0830524785 0.0830524785 0.0983124785 0.0983124785 0.0983124785 0.0983124785 0.0983124785 0.0983124785 0.0830524785 0.0830524785 0.0830524785 0.0830524785 0.0830524785 0.0830524785 0.0830524785 0.0830524785
17 0.0524047279 0.0676647279 0.0829247279 0.0829247279 0.0981847279 0.0981847279 0.0981847279 0.0829247279 0.0829247279 0.0829247279 0.0829247279 0.0829247279 0.0676647279 0.0676647279 0.0676647279 0.0676647279 0.0676647279
17.5 0.0523664027 0.0676164027 0.0828764027 0.0828764027 0.0981364027 0.0828764027 0.0828764027 0.0828764027 0.0828764027 0.0676164027 0.0676164027 0.0676164027 0.0676164027 0.0676164027 0.0676164027 0.0676164027 0.0676164027
18 0.0523549052 0.0676149052 0.0676149052 0.0828749052 0.0981249052 0.0828749052 0.0828749052 0.0828749052 0.0676149052 0.0676149052 0.0676149052 0.0676149052 0.0676149052 0.0676149052 0.0676149052 0.0676149052 0.0676149052
