shreveport/bossier hang out!
I'm here for good but since the Facebook format is easier to use, we could always create a local only LSX group. Some of the posts on monsters are starting to remind me of the conversations on the New Orleans post here on Tech.
Free Chilton's manuals online: The login information is any 1 letter followed by ANY 12 numbers. As long as its in that format it will let you on.
https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL
Steve, I talked to Josh the other day. I told him yall need to let me know next time you all go to Highlifter park. I've been wanting to go check the place out but I didn't want to go by myself. I have a Teryx sitting in the shop that I need to use at some point
Nice ride.....good thing its got a winch, you'll prolly need it at highlifter before the day is over. We'll be sure to let you know when we go.....I believe there was a group that went this past sat but I couldn't make it.
Not much of a winch but it did get me out of a jam a few weeks ago. It needs some good tires bad. This thing is not like my 300ex honda, when it gets stuck, it is stuck. It is like getting a truck out
i had a blast last weekend at highlighter. went in the nastiest stuff ive ever been in. didnt have to use the wench once worked my way threw it all Nice now that ive got this thing learned!
C.Ainsworth, Shriners ride Dec 1st @ Highlifter. Should be a hell of a good time. We are bringing an alternate follow along mini-4wheeler just to carry beer. Hope yall are thirsty, its only purpose will be to carry cold beverages.
Tough Mudder
I'm around. I see the new posts. Read them. Reply as appropriate.
Guess I'll update.
Corvette is still sitting. I haven't even drained the oil.
Boat is coming along. I built an A frame to lift the motor out of it.
Here is the engine, transmission, and most of the exhaust coming out
End result
Excuse the cluttered garage. We got Christmas down from the attic the other day and found a lot of stuff that has to be given away. Two kids is ENOUGH!
Now to replace the stringers, put down the floor, do a little fiberglass...
I'm going with the foam insulating sheets. I plan to glue them to the hull, then to each other, then another layer of glue beneath the floor.
Guess I'll update.
End result
