Finally got some track times
Old Sep 12, 2003 | 11:58 PM
383LQ4SS's Avatar
Default Finally got some track times
err..i should say track time...I was kicked off after the first pass.
I was jetted down to about the 630 rwhp level and not using the nitrogen push. Full tank of gas, approx 3525 race weight. Stock six speed manual with stock 3.42 ten bolt rear, Ram clutch, Panhard bar and LCA's, Draglites/ET streets.
Just wanted to make a shakedown pass since its been about a year since the last track runs with nitrous. Staged...reved to 4000 rpm and dumped the clutch and immediately sprayed,and then rowed through the gears casually.
1.55
6.734 at 107.10
10.398 at 134.95
Then was promptly told I needed a cage to run again. So I didnt get to hit it with the big shot or get a lil more agressive on the driving...oh well. The cage will be in soon. As will a real rear/gear/tire combo.
Old Sep 13, 2003 | 12:49 AM
W8N2SQZ's Avatar
Default Re: Finally got some track times
SWEET way to go Al. I have been waiting for you to post some times. NICE MPH. Keep us posted when you go again.
Let me get this straight, you went a 1.55 short time on the stock rear and 3.42 gears does the rear make noise now
Anyhow, congrats on the set-up!
Glenn
Old Sep 13, 2003 | 01:04 AM
W8N2SQZ's Avatar
Hey Al, I know you took out timing with your special Maf tunning via frequence change, but did you also add fuel when the ECU see's the changed in frequence as well??
Thanks
Glenn
Old Sep 13, 2003 | 07:48 AM
EVIL's Avatar
thats awesome!!!!
on a 10 bolt....
Old Sep 13, 2003 | 09:11 AM
BADZ's Avatar
Moderator
That's what I was thinking, (10 BOLT)
Old Sep 13, 2003 | 09:30 AM
383LQ4SS's Avatar
It was a private track day open to only about 75 cars. This track is fairly liberal enforcing the rules. So I decided to go ahead and make a few runs. I keep a lil extra tire pressure in there so it slips off the line a bit as not to grenade the rear. Although this 10 bolt has seen many high 10 second passes. It seems to be quite strong.
I will not be headed back until the 12 bolt is in. It will likely be a 12 bolt with 3.90 gears and 28" ET drags. REally lauching hard with that combo and the full shot should lop some time off. Its going to ba a few months though. Other priorities for a while.
Old Sep 13, 2003 | 02:41 PM
CAT3's Avatar
Restricted User
Very Nice....
Old Sep 13, 2003 | 03:07 PM
383LQ4SS's Avatar
Thanks
Glenn
Actually no. Although we can do that...and probably will, along with a few other fine tuning items. But..the current tune is still light years ahead of what is used to be. I looked at the scanmaster at the top of the track on that run...0 knock.
Old Sep 13, 2003 | 03:35 PM
Robert56's Avatar
Very nice numbers, you have one Bad Azz car.
Old Sep 13, 2003 | 04:43 PM
Z-Rated's Avatar
man 134.95 is just stooopid
get that 12 bolt and a cage and head to the track again. Can you get a in car camera view??
Old Sep 14, 2003 | 01:29 AM
W8N2SQZ's Avatar
0 knock is beautiful. Way to go
Glenn
Old Sep 14, 2003 | 05:34 AM
VINCE's Avatar
Shorty Director
I ran a 149mph pass in my mind.. Congrats Al..
Old Sep 14, 2003 | 11:43 AM
rarin11's Avatar
congrats that is awesome
