Nitrous build up TEASER pics
I'll post a write up on the entire build when we're finished. Enjoy!
How it all began......
Stripped stock motor down.
Stock core support removed, N-motion timing chain, head studs
water pump, ASP balancer, alternator mounted...CNC ported 5.3L heads
Setting up the dedicated tank....
Fabricating new core support....
Tons of room now...enough to stand inside the space to work on the motor!
NX kit plumbed by Jeff Prock..
2. more room to work on the motor, we all know how much of a pita it is to work with everything tangled up. Also the computer is mounted under the dash, and re wired so its much cleaner under the hood.
3. I have a 76mm turbo that is not going on yet...
