my car Hesitates 100shot pills set @3200
outa the Hole,...a4 3800 stall, Do you guys load the converter or do just flash it?, floor it..............outa the hole?......my car hesitates, for about 30ft than the spray kicks in........my 60ft has been 2.1.....it should be 1.6
H/c/i............
H/c/i............
Guest
Posts: n/a
Do you have a purge?
Length of lines from solenoid to nozzle/plate
Window switch activation points.
I launch from just above idle (1100 rpm or so)...flashes to 5000 on the 200 hit.
i purge @ burn out...
Guest
Posts: n/a
sounds like the fuel is beating the nitrous to the motor... do you have a way of watching A/F ratio when you launch?
Try manually purging the nitrous at the solenoid before your next run....this can be done by opening the bottle then loosening the fitting at the solenoid until you get a good cloud from the leaking fitting. Tighten it back up and you are good to go.
and what my 60ft is..............tanks !!!!!!!
well i went to the 1/8 track last nite, no change my car just doesn't come out of the hole with a bang, my trap was 97.40, 60ft 1.9, and 1/8 time was 7.44.....i have gone 1.6.........pills are set at 3200...100shot...
