g5x2 and nitrous?
Old Sep 23, 2003 | 01:03 PM
jamescb77's Avatar
Default g5x2 and nitrous?
Will this be a good combo or will i run into problems also i will be running a stage 2 set of pace 5.3 heads. Do you guys see any problems with this combo if so let me know what i should change thanks jamescb77
Old Sep 23, 2003 | 11:31 PM
Louis's Avatar
Default Re: g5x2 and nitrous?
JS12 went 6.7x in the 1/8th, cam only on a 90 rwhp shot if that helps
Old Sep 24, 2003 | 09:00 AM
Chicago Z06's Avatar
I run 136 MPH with a 150RWHP shot in my Z06... GTP LS6 heads and G5x2 on 114 lobe.....
Old Sep 24, 2003 | 10:02 AM
VINCE's Avatar
Shorty Director
Sounds like that cam likes spray..
Old Sep 24, 2003 | 05:42 PM
Country Boy's Avatar
Senior Member
Hummmm.........
Old Sep 24, 2003 | 06:53 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
I think brent from tea went 9.80 with a clone g5x2 and his 5.3 heads nothing speical according to him. I think he had one wet kit and one dry kit.
Old Sep 24, 2003 | 06:54 PM
VINCE's Avatar
Shorty Director
The only problem I see is gear selection.. If you spray anything over a 100 shot on the street with 3.73's or 4.10's you will have traction problems. It seems you would have no choice but to sacrifice NA performance for Nitrous performance.
Old Sep 24, 2003 | 07:28 PM
Louis's Avatar
N20 is usually that way!
Why do you think that the ARE Vette ran low 11s on motor, and went 9.2 @ 15x on the juice?
Life is full of compromises, take your pick
Old Sep 24, 2003 | 08:00 PM
jamescb77's Avatar
sounds like i should be good to go then thanks everyone.if you have anymore input feel free to add.
Old Sep 24, 2003 | 09:23 PM
blkbeaZ28's Avatar
We are trying to get Lou to give us a GP on these check click here
Old Sep 25, 2003 | 12:11 AM
jamescb77's Avatar
can you give me the specs on the g5x3 cam i haven't heard much about it but if it is streetable then i may consider it instead. thanks also what are osme numbers that have been put down with it jamescb77
Old Sep 25, 2003 | 01:26 AM
bigSS's Avatar
Good lord!
Old Sep 25, 2003 | 10:07 AM
VINCE's Avatar
Shorty Director
I agree.. I was running low 12's on my old setup and I was only making 390rwhp.. I think with 3.42's in this setup I should be able to run atleast a little better. The difference that I see between my old setup is my T1 cam had more tq down low than my current setup.. I am building a Road Race setup and weekend street setup to have the best of both worlds..
Old Sep 25, 2003 | 01:07 PM
Louis's Avatar
X3 is currently on hold for the public untill further testing is complete. It did trap 98.3 in the 1/8 with a set of Absolute speed S2.5 LS6 heads, NA, with a 2.1 60'. The car was a C5 at the Z06 fest in Bowling Green.
Drivability is a tad better, but right now, we have a whole new line of cams currently being tested, so look for more news on these soon!
Louis
