new to n20 and going crazy
Old Jan 10, 2009 | 02:06 PM
WombatRacing's Avatar
Originally Posted by ShiznityZ28
10.5 is pretty rich then changing to a tr-6 could make it even richer.
First i would mak sure the notrous if firing by removing the nizzle pointing it away from mthe car and grounding the trigger. the plumb should be powerfull and want to push the line also it should be a bright white.
If thats good go for a ride and go to wot then hit the arm to have it come on and let it get a af reading. IF its in the low 10's or 9's start leaning it out to see if it gets better.
The problem with the pop and bog sounds rich to me.
the pop and bog stays even if i lean it out ive tried
Old Jan 10, 2009 | 02:23 PM
ShiznityZ28's Avatar
Did you make sure the nitrous is spraying? if you get only fuel it will pop and bog for sure. Know anyone else with a bottle? hook another fresh bottle up. Could have been a bad fill.
Also try doing it with the bottle turned off but armed does it do the exact same thing? that would give you an idea.
Old Jan 10, 2009 | 02:41 PM
Robert56's Avatar
Also, IIRC, you stated your plugs are gapped at .050, that is a little wide and i would get em closer to .030. My #7 street plugs i run at .028 gap. Might be blowing out the spark as part of your problem. The Autolite plugs that white suggested are good plugs and likely what i will be going to once I use up all of the NGKs we have. the TR6 plug, IMO, for anything over about 150 is junk, and maybe even prior to 150, lol, but seems to be the industry standard.
Robert
Old Jan 10, 2009 | 02:47 PM
I would agree a 6 might not be optimal but should not cause the issues he is having.
Did you regap the 6's to .050? they come ~.035.
Robert FYI. those auto lights are harder to melt so work your way up. once they show you a sign and even just start tyo get a tip the piston is probably hurt. Id get it dialed in on ngk's then swithc once your tune is perfect.
Old Jan 10, 2009 | 03:51 PM
nitrouus is def is spraying, i was thinking it could be a bad bottle so i have a friend bringing another one to day,
with the bottle off i hit unit it bogs from fuel but no poping and etc
Old Jan 10, 2009 | 03:54 PM
Robert
i had started the plugs at .035 and after having these problems a friend of mine suggested taking it wider(i don't think he really knows what hes talking about)
so i figured it couldn't hurt anything so i tryed it
Old Jan 10, 2009 | 03:57 PM
on my life
well ive call and went by every auto parts store where i live and nobody with have anything i could use untill wensday
so no fun for me tonight i guess
Old Jan 10, 2009 | 05:31 PM
99345hp's Avatar
I think your suffering from a misfire and thats why the wideband is showing rich. I dont get how the plugs have a white tip with it running that rich though. How long do you drive it after your nitrous runs before you check the plugs?
I would go somewhere where you can safely use the nitrous. Then hit it, quickly stop, shut off the engine, then pull plugs and check them. This will give you a better reading of whats happening while the nitrous is on.
Old Jan 10, 2009 | 05:55 PM
Nick@HSW's Avatar
I agree with Robert. We need to back track to when you weren't having issues. First and foremost, we need to get those plugs back out and get them gapped correctly. Any troubleshooting without first doing this in my opinion is a waste of time. While their out, inspect them. Are there any cracks in the porceline? Are the wires in good shape? All of the connectors still in-tact? I only say this because once you did a plug change things went awry. And since its all coming out again, just check it.
If you're also seeing that low of an a/f, you can lean it out slightly with the Interface. Just start out in small incriments and make certain your wideband is accurate.
Nick
Old Jan 10, 2009 | 08:04 PM
well i have a half-mile of (not busy)road to the side of my house so i make a 2 gear pull and turn off and coast to my house
Old Jan 10, 2009 | 08:11 PM
Nick
well when i had pulled the plugs to regap i had one plug that the strap was burnt and the porceline around the eletrod was chiped ill take a pic of that in a minute
Old Jan 10, 2009 | 08:29 PM
  #32
Old Jan 10, 2009 | 08:34 PM
  #33
Nick@HSW's Avatar
I hate to tell you but that looks melted not chipped and there appears to be speckling on the ground strap. Are you sure that wideband is working and calibrated? I'm beggining to wonder if you might have done damage on that cylinder when the stock plugs were in there. What cylinder is that?
Nick
Old Jan 10, 2009 | 08:44 PM
  #34
that was cylinder #4
Old Jan 10, 2009 | 08:46 PM
  #35
my wideband is a aem uego and i seems to work fine i get a steady 11.8 afr on all motor passes(my tuner set it real fat)
Old Jan 10, 2009 | 08:57 PM
  #36
Nick@HSW's Avatar
I would double check that the injector on that cylinder is functional and plugged in.
Easy way to verify cylinder is a leak down. Do you know anyone that has one so you can see if there is any damage?
Nick
Old Jan 10, 2009 | 09:50 PM
  #37
white2001s10's Avatar
do you by chance now what heat range those plugs are, i wanted to get some autolites but in the spark plug chart in the sticky somebody said that they were listed wrong?
AFAIK the autolite AR-472 is as cold as it gets in that plug style.
Can you post pics of the other plugs you pulled out besides the damaged one?
Old Jan 12, 2009 | 05:21 AM
  #38
Robert56's Avatar
Thanks for the heads up.
Robert
Old Jan 12, 2009 | 02:44 PM
  #39
i picked up some ngk #8s today so im going to put those in and see what happens what do you guys recommend for gaping these plugs??
im assuming .030 would be good ?
Old Jan 12, 2009 | 03:05 PM
  #40
nahasapeemapetalon's Avatar
Get not projected tip ngk's........
