MS3 + N20..need help
what would be better for my application? I have a 01 LS6 long block, MS3 is going in with the Livernois .690 valve spring kit, ported LS6 oil pump etc. for the cam install. I want to do just a little 50 shot. Should I do a wet kit, or a Dry? I might also add my inline MSD fuel pump I have laying around just to bump up the fuel pressure on the stock injectors a little.
also, I want this to be 100% stealth hidden. Im gonna put the bottle where the spare tire is, put vac. line over all the lines in the engine bay...but whats the best way to hide the nozzel itself?? Can I mount it under the intake right before the throttle body or will the spray pattern screw up the MAF from mounting it that way.
The only problem i would see with the dry shot and the NA power you will be making is your injectors may be maxed out. IF you can figure out where to hide the solenoids, our wet plate kit actually makes for a really stealthy install. IF you cover the lines in vacuum hoses most people wouldnt be able to tell.
is their any difference in reliability between wet and dry?? This is a brand new motor and I dont want to harm it.
I was also told with only running a 50 shot, I wont need a tune...
http://www.harrisspeedworks.com/gall...s.php?album=28
http://www.harrisspeedworks.com/gall...s.php?album=51
Wet kits can be hidden as well
http://www.harrisspeedworks.com/gall...s.php?album=47
Little bit more difficult since you have another solenoid, lines and larger nozzle. If you order from us you can get custom colored lines and fittings. If you dont do that you can do what you were saying, run the lines in vaccum hoses so they would appear to be stock.
on sale for christmas. Other than a colder set of plugs you wont really need anything else. The optional pieces of equipment would be Blow down tube (if you go to the track you need one), nitrous filter, purge, bottle heater for consistent bottle pressure, microedge controller (window switch and A/F shutdown) and the interface controller to pull timing if you would like. The interface would also allow you to put the nozzle anywhere you want, even POST-MAF. Makes tuning your shot a breeze
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
