NX solenoid won't close all the way.
another question kind of related, what may cause a solenoid to not open when at operating pressure anymore? this is a cold fusion noid btw. Worked fine a few times then just quite working at higher pressure, but will spray just off the 600psi bottle pressure alone.
I sounds like a weak coil. What are you meaning by "high pressure"?I've seen solenoids fail to open @ 1200 psi but be fine at 1000.You may want to borrow another gauge to verify pressure.
The guage is brand new and works fine, the solenoid used to work but the kit was used. I sprayed around 1200psi at first then it just quit working at that high of psi and would only open when at say 600-700psi.
If you pop it open and you can't find any debris I would inspect the stainless steel seat to make sure its not leaking past the press fit.
Nick
