LSX Shootout Class
The weight sounds good, I can stop spending $ on LW **** right now cause with the hatch and rear window alone I'm under the weight limit. Guess I can add a fire system and a parachute as a couple good idea safety items to get the weight back up, better that stuff then a box with lead shot in it.
If they're gonna limit it that way though, I'm putting my 4.10 gears back in the car, and just get that intake swap done, maybe get a vacum pump on the car, but honestly that crap wouldnt' be enough to get me close to the motor hp you'll be making this year I'm sure. Your heads are probably 75 hp more then mine.
We will see what they do, Maybe they do a fast N20 class and I will come.
Maybe they will do a slower one (sounds like they are leaning that way) and I wont come, I wont be mad either way.
You can go up or down which is good thats the kinda guys there looking to set the class up for.
Thats a Joke..... if anything it AT LEAST needs 3 weight category's, even then it's skewed.
346-370-3100lbs
371-396-3250lbs
397+ 3400lbs
4 might be considered fair
346-370-3000lbs
371-396-3100lbs
397-427-3200lbs
427+ 3300lbs
Add 100Lbs for aftermarket blocks if you for some reason you really want people at 3400 lbs
I don't know the exact # that should be at what weight, but adding x amount for every Ci is probably a good idea.
I've love to see this class mandate a 275-60-15, ET 28x11.5, and no slicks. Making the car work on the tire is what will make this class interesting, not who has xx size pills with a 408ci iron block.
I know weight is one way to go at this, but I'd like to see big cubes run less nitrous, and high strung stock cube guys allowed to run 100hp more of nitrous.
I could see a lot of low 10 second guys stepping up for this class as long as it didn't have big holes in it.
Scott if you have a chance I need to touch base with you about something... Call me or I will call u.
8x346-2768
8x402-3216
8x427-3416
346x8.7 = 3010.2, call it 3010
402x8.7 = 3497.4, call it 3497
454x8,7 = 3949.8, so call that 3950.
It would stop someone from just building a massive 500 inch motor that with very little nitrous at all be capable of running in the 8's for sure.
The 26 inch tire Wayne, that's intresting. But, you know as well as I do that there's guys running mid to low 5's to the 1/8th on the 26x8.5 tires, so I dunno if that would really be a limiter like you think.
Those are pure purpose built race cars. and they dont weigh 3400lbs.
I want to see you strap them on and get down.
high 9sec nitrous cars already have a place to race...its the index showdown
this should be a complimentary class to the outlaw 315 (err...295
) DR class where the N20 cars can't keep up with the turbo cars...slap on 275s and run whatcha brung...as long as its a LSx-based nitrous combo...
as a spectator, I'd rather see all-out nitrous cars instead of watered down combos...the premiere heads up classes should offer at least some excitement
j/k problem with that is you end up with a 4 car field. There are several low 8 second (possible high 7) nitrous cars around here. If the rules are setup like that, the class will never be filled. I do see where you are coming from in terms of excitement for the class. Right now i think everyone is more concerned with having a full field.
i.e. cam only car
h/c cars
small turbo cars
etc...
how many 8.0 Nitrous LSX runs have there been on 275s?
BTW...I see 15 votes for 8.0-8.99
i.e. cam only car
h/c cars
small turbo cars
etc...
I'll go to that tire right after you do LOL. I tried that once when I was running the car n/a, just to see if the car would like a 4.30 gear instead of the 4.10 I was running (shorter tire same effect) Chef had a set of 26x8.5 et drags on his convo pro's, so I figured why not try it one day.
Footbraking the radial was no different then transbraking on that tire.... results were about the same. BUt, I did have to drive the car for 1/2 the run.....
Add the nitrous power to that, no thanks LOL.
