MS4 and Spray what times are you running?
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
Like the title says what kind of numbers are you guys running at the track with how much nitrous. I have a ms4 car stock heads and every bolt on with a th400 with a 4k yank custom stall with n20 in mind, 3.73 gears, 42 lbs injectors and a timing tuner to retard timing & my nitrous kit is a nitro daves plate system and want to see what kind of times are you guys running I plan to spray 100-150 shot thanks in advance.
10.5 after getting off kit about 500ft before 1/4 and coming threw on the gas 126mph.me and a 10.3 car going at it i was a car lenth in front till i hit the limiter and had to come off spray. so i would say i was good for maybe a 10.2 pass 1.4 60. i had etp 215 ,fast 90/90 tnt i set up pills to be a 162 -165 shot useing a nos calc. 4.30 gears m9 rear th350 3800 vig, 42lb inj. thats my old set up hope it helps someone else
With the ms3 and a 200 shot went 10.1 full weight car on a 370 though. I would invest in some heads if I was you that will help that cam alot. I think you are being limited. I went 11.10 NA w the ms3 and patriot heads 4l60e 3500 stall last years set up.
