HSW single nozzle Install help
thanks
The SLP bellow is easy, stock is not.
I've seen some people drill through the maf end and tap it when using a stock bellow.
I should use a bit thats around the same size as the nuts that threads up to the nozzle correct? Then have one side insde the bellow and the other nut on the outside holding on the nozzle? sorry if thats sounds confusing
Anyways for the fuel line. Do I unscrew the shrader valve and screw the nitrous line directly onto the fuel rail? Also with it not being wired, the noid will be closed correct? Or should I wait untill everythings wired up to screw in the fuel line?
You will need to remove the valve first.
The tool is a couple dollars at autozone.
