Low Pres Stand Alone
Old Apr 8, 2009 | 04:23 PM
TexVette's Avatar
Default Low Pres Stand Alone
If I wanted to fab up a stand alone fuel system for my nitrous but wanted to use a low pressure setup, what would my target fuel pressure be? Would there be any flow requirements?
Does anyone want to recommend a specific pump?
Old Apr 8, 2009 | 04:30 PM
1 QUIK LS1's Avatar
I don't know abouut other people...but i have a holley blue fuel pump on my stand alone system and run 6 1/2 lbs flowing and a square jet patteren. Been running it that way for 5yrs and runs great for me.
Old Apr 8, 2009 | 05:01 PM
TexVette's Avatar
How big of a shot?
I guess I'm looking for info for about a 200 shot.
Old Apr 8, 2009 | 07:50 PM
Randy WS6's Avatar
I run 12psi with a Holley blue pump. But i use a wide band to set it with.
Old Apr 8, 2009 | 08:15 PM
SPRAYIN96TA's Avatar
Originally Posted by TexVette
How big of a shot?
I am running a Cold Fusion Fogger with there stand alone kit as well. It is a "low pressure" system. I am running a 28N/24F tune up. I started @ 6.5psi and worked down from there. Just be sure to read the plugs and adjust timming and fuel from there. When you do set your fuel pressure, dont dead head the system. Set if flowing.
Old Apr 8, 2009 | 09:58 PM
Nitro Dave's Nitrous Outlet's Avatar
I tend to shoot for around 10psi on my low pressure set ups. 6psi is really common as well.
Dave
Old Apr 9, 2009 | 12:16 PM
TexVette's Avatar
Thanks for all the replies.
If I was going to use a holley blue pump would I want the matching fuel pressure regulator? I ask because the one summit recommends is returnless.
Do I want a low presure stand alone setup to have a return? What about a vent on the cell? Is there a need for both of these?
Old Apr 9, 2009 | 01:24 PM
by the time you peice everything together you are better off to just outright buy a kit already setup. I suggest this one. I run it on my TA and it is the ****!!
http://www.coldfusionnitrous.com/fue...?CategoryID=47
Old Apr 9, 2009 | 04:13 PM
1 QUIK LS1's Avatar
How big of a shot?
Thats what i'm spraying
Old Apr 9, 2009 | 05:41 PM
02 BLK WS6's Avatar
That's a nice kit, but you can build you're own low pressure kit for less than $300.
I'm putting together a high pressure kit. Parts have cost me $385. I should have it installed this weekend.
Old Apr 9, 2009 | 10:34 PM
DopdBrd's Avatar
I had a low pressure homemade kit on my car and liked it other than the fact that it was not a return system. Rigged it up and made it work.
Then bought a used Harris Speed works kit for 425.
Old Apr 9, 2009 | 10:36 PM
waterbug1999's Avatar
Im doing the same thing... I have it priced for ~$330 for everything. Let me know how it works out. Shoot me some pics.
