red loctite
Old Apr 22, 2009 | 01:12 PM
jrwireman1960's Avatar
Default red loctite
how long should you give it to set up before turning on the nitrous?
Old Apr 22, 2009 | 02:10 PM
TARZAN's Avatar
I don't know an official time....but I usually try to give an hour or so, and I've never had any problems.
-Will
Old Apr 22, 2009 | 02:14 PM
89IROC's Avatar
only takes a cpl minutes and its good to go, loctite is an anaerobic sealer so it hardens in the absence of air...i had a demonstration of permatex thread sealants where the guy put on a cpl drops of there red on a bolt, screwed it into a nut and passed it around with 2 wrenches and no one could break it lose after setting up for only about 30 seconds...
Old Apr 23, 2009 | 09:51 PM
=ZoomZ='s Avatar
671 is what i used in the paintball industry and it will hold 3000 psi by the time i would get the gun together ,, lol
Old Apr 23, 2009 | 10:56 PM
samson_420's Avatar
Like mentioned above, it sets up instantly. . . . . . . Pretty much.
Miracle stuff. . . .
Old Apr 24, 2009 | 10:37 AM
Nitro Dave's Nitrous Outlet's Avatar
I have put things together with Loctite and try to take it apart a few seconds later and had to heat it up to break the loctite loose. It sets up under pressure pretty much instantly.
Dave
Old Apr 24, 2009 | 10:52 AM
=ZoomZ='s Avatar
One thing i did notice is that if your sealing up a fuel line , you need to let the loctite sit up longer .
I would seal a fuel line and test it for leaks and it wouldnt hold but after cleaning the fittings an resealing it and letting it sit over night , it never leaked again .
Old Apr 24, 2009 | 11:11 AM
Chris@NitroDaves
Guest
Posts: n/a
I'd give at least 5min at the minimum of solid drying time to be sure.
-Chris
