nitrous guys that change plugs often, quick question
Old May 16, 2009 | 05:25 PM
gator's 99TA's Avatar
Default nitrous guys that change plugs often, quick question
do you guys use anti-seize every time you change plugs? Dielectric grease in the rubber?
i am talking about guys that pull plugs every trip to the track on nitrous.
Old May 16, 2009 | 06:23 PM
INTENESS's Avatar
I used it once and then I have gone threw about 12 plug changes and I did not add anti seize and its just as easy to get them out or in.
Old May 16, 2009 | 07:38 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Every new set that go's in has antiseze on the threads.We do no put more antiseze on the plugs when they go in and out of the motor.My car gets a new set of plugs before every race or test night.We warn up the motor on the set from the prior race or test.
Old May 16, 2009 | 08:44 PM
yes, i am talking about new plugs. thanks.
Old May 16, 2009 | 11:59 PM
WE TODD DID's Avatar
I never use either. Plugs come out of the engine after every pass. Just don't over tighten the plugs. A snug fit is fine.
Anti-sieze inside of the combustion chamber on a nitrous engine is something you don't want.
Old May 17, 2009 | 01:04 AM
ShiznityZ28's Avatar
Nothing. there not in long enough to need it. my motor plate mid plte solid tranny mount car we had to blue lock tight the plugs cause they keept lostening up.
Old May 17, 2009 | 04:12 AM
AutomagicLS1's Avatar
Ive changed my plugs 3 times in the last month each time they have anti seize on them.
Old May 17, 2009 | 03:50 PM
Robert56's Avatar
Anti seize on all new plugs here. Dielectric grease in the boot every now and then.
Robert
Old May 17, 2009 | 05:49 PM
i guess it really breaks down to if one changes plugs every pass/trip to the track or every few weeks/months. guess it really depends on the type of plugs and how often you race lol.
Old May 17, 2009 | 08:52 PM
ls2 bait's Avatar
i use dielectic grease on my boots and change them every 6 months or so and they are still a pain in my *** to get off so im not sold on that one.
