cam choice
Old May 17, 2009 | 05:30 PM
pozesd99''s Avatar
Default cam choice
right now im running a tsp 224-r cam. but i want something a little bigger, something like a ms4 or even a trex cam.
how will these work with nitrous? i plan on spraying a 200 shot...
and where can i find these cams
Old May 17, 2009 | 05:41 PM
blackls1ta00's Avatar
trex is good choice from thunder racing but need ptv clearence checked,also ms4 is a great choice also from texas speed and performance,i would check ptv either way,make sure you have bolt ons to accompany cam,good luck on choice.
Old May 17, 2009 | 06:00 PM
pozesd99''s Avatar
well i would obviously get all the neccessary pushrods, lifters, springs, retainers etc...
which is a better cam for nitrous, but i still want the choppy lope.
and whats is ptv
pozesd99''s Avatar
what lsa should i get
Old May 17, 2009 | 07:01 PM
well i meant like an underdrive pulley with cam,air lid,full exhaust,etc,trex is 109 which isnt for daily driving and ms4 is 111 lsa which wouldnt be bad,ptv is piston to valve clearence for stock engines it NEEDS to be checked or possible flycut your pistons if it wont clear,theres alot involved,know what your getting into,read up before doing or have a reputable shop install and get it tuned.
Old May 17, 2009 | 07:04 PM
both cams run excellent on nitrous,depends what rear gear and tire your running too,theres alot involved ,you have to have a proper setup for these cams to work great together.
Old May 18, 2009 | 08:54 AM
Nick@HSW's Avatar
Honestly unless this is a full bred race car that never makes a pass without spray, I would make cam selection based on your n/a requirements. Let me know if I can be of any help. Thanks.
Nick
Old May 18, 2009 | 09:47 AM
Ruckus46Gt's Avatar
mike just gonna say bigger isnt better. Ptv is piston to valve clearance as someone probely already chimed in. Worst case might have to flycut the pistons a little. This for the 408 you built or did you move to just a reg ls1 again?
Old May 18, 2009 | 03:16 PM
pozesd99''s Avatar
^^^ i'm gonna text you jeff
Old May 19, 2009 | 11:48 AM
pozesd99''s Avatar
so the ms4 is going in a lq9 6 liter with ls1 heads. i know that you must sometimes modify some things to use the ms4 in a ls1 but how do they work with the 6 liters?
Old May 19, 2009 | 04:48 PM
pozesd99''s Avatar
bump need answers quick lol
Old May 20, 2009 | 05:35 PM
bluestrat's Avatar
Stock cam is the best choice, lope is overrated...
Old May 20, 2009 | 06:52 PM
pozesd99''s Avatar
your so gay bob! happy late 21st too
k i'll run ya motor to motor, then tell me cams are overrated lol
Old May 21, 2009 | 01:17 AM
ssfast99's Avatar
well i have installed 6 t-rex cams in various engines and never had ptv problems but should check just in case. my t-rex loves nitrous and i drove the car 45 miles from the track after it ran a nitrous pass. t-rex makes awesome power on motor and loves nitrous.
Old May 21, 2009 | 08:19 PM
pozesd99''s Avatar
where can i buy a trex cam and what springs must i run? 918's fine? and what lifters?
Old May 21, 2009 | 08:45 PM
pozesd99''s Avatar
so now im thinking either a trex, ms3, lg g5x3, or a torquer v3. whats your guys opinions. again this is going in a 6 liter with ls1 heads and not driven everday...
i want great sound with good power
Old May 21, 2009 | 10:17 PM
BAKED's Avatar
Get a custom cam.
If not, I'd go with an X3 on a 114 for your setup.
Old May 22, 2009 | 03:44 PM
bluestrat's Avatar
Thanks man. I totally agree with you BTW, just trying to help you sandbag
Old May 22, 2009 | 08:26 PM
pozesd99''s Avatar
how do i decide what type of lsa i want in a cam
Old May 23, 2009 | 02:35 PM
krobinson123's Avatar
get a custom grind
