My Nitrous setup topped out?
I have 2 n20 bottles with -4 line up to a Y fitting then to my solenoid, -4 from solenoid to n20 outlet plate.
I dyno'd yesterday with a .073 jet .038 fuel jet and made 542rwhp. I increased the n20 jet to 078 and .082 and only increase a few rwhp. 560 was my best.
I only increased the fuel jet to a .040 and it stayed equally rich, it leads me to think something is limiting my n20 flow.
Any thoughts?
Also my n20 setup didnt work with e85 tune, was surgy.
Other factors in flow are solenoid designs, bottle valve design etc. All these are factors on max HP. But more than likely it is either your solenoid or plate that limits your ability to make power
Back to the topic, yea its a little rich, but when increasing the n20 jet it remained equally rich.
The plate is rated for 400hp, the solenoid has a .090 oriface. Its the new NX solenoids (carbon fiber ones) i can use one with a larger oriface, but thinking thats not the problem.
Ill check fittings and make sure its a -4 line from solenoid to plate.
Yea we added fuel for e85. I tried many things to cure n20 e85 problems and couldnt.
A/F was probably high 11's low 12's.
I better verify somehow its not a -3 line, that would make sense.
But, i am pretty sure i ordered a -4 line with one end a -4 end and one end -3 for connection to plates and nozzles.
its hard to see but i have a 90 T fitting off of the main line for the fuel solenoid. Its on the right of the picture after the fuel rail.
I can check my fitting that is for my pressure sending unit, to see that it looks like it flows well enough.
Also, why not swap out to a -6 feed line straight from the bottle to the line? I think your jetting is for like a 230ish shot. That is alot for a single -4 line (which is after the Y) to physically flow, even though the line is .250 diameter.
Yea its pulling fuel at the front end of the fuel rail, fuel pressure did pretty well. Might have dropped 3-4 lbs but thats probably normal?
Is your motor tune dialed in? That's the problem I'm fighting right now. I was trying to cover tune issues with nitrous jetting. It doesn't work so well. Is it tuned for E85 right now, or are those #'s on gasoline?
