Innovate WB/lean shut down switch question
I don't daily drive this thing or anything, but it sees street use. Do guys who run this setup just keep the WB on all the time? I know it can be removed, which means removing the sensor so it doesn't foul, which seems like a pain in the *** and renders my nitrous unuseable. My other choice is to keep the WB powered up every time I drive the car, not sure if thats a great idea or not? I haven't done alot of reading on the WB setup, I know it can be run constantly, but do I have to mess with the calibration every time I start the car or power it up and down? If I just wire to the ignition (vs the cigarette lighter) will it just power up and run every time and be hassle free?
Or should I just use the WB to tune and wire the cut off to the stock sensor?
Thanks
A rich shutdown switch.
A Wrong plug shut down switch.
A To much timing shut down switch.
How lean does it have to be before it shuts off anyway?
I've always wondered that too.
On a side note, i am note sure why they don't include rich shut down settings on these. Its almost as bad as going lean. I don't see it taking much more to incorporate that and make it like a window switch for AFR.
Robert
Robert
Robert
In my setup, the wideband gauge reads about .4 richer than the display on the lean shut down switch. Since the lean shut down switch is hid away it doesn't really matter. I just know that if I want the switch to kill my system at 12.2 then I set it for 12.6.
