How to wire warmer?
Thanks, Justin
Thanks, Justin
I'm sure there is a how-to page somewhere around here...
Is it a NOS system?
I hooked mine up to 2 pincer clips and I plug it to batery +,-
The only thing is I have to monitor the bottle pressure carefully so it doesn't overheat. It's no problem for me as I only use N2O with a warmer at the track, so I get the pressure up, unhook the heater, do a run and voila.
you need some 10 gauge wire running to the back.
and second, you need a control device, if you don't have one, you can skip it.... but you better keep a close eye on the temperature.
for the wiring, the relay will have 4 wires. 85 86 87 30
30 goes to battery, fused.
87 goes to one wire on the heater pad
85 goes to control device, then that to ground
and 86 connects to your switch, which provides +12 when the switch is on.
Ground the other end of the heater pad, and your set.
Ryan
, Justin
