Installing Nitrous
Old Oct 5, 2009 | 06:02 PM
02spooledupWS6's Avatar
Thumbs up Installing Nitrous
I Have never installed nitrous before and i plan on installing it in my 02 WS6 about how long does it take to complete the installation process? And how hard is it? I have a sts turbo on it so i dont know if it will affect the installation as well...
Old Oct 5, 2009 | 06:09 PM
waltsfastz's Avatar
Not too bad, just take you time and do it right the first time, and it will look beter as well. Instalation is about asking how long to build a house. a dry kit is pretty strait forward, wet obviously takes londer. If you install heat,purge, Window swiitch, controler it then takes longer.
Old Oct 5, 2009 | 06:56 PM
nikon1999's Avatar
i've seen people throw a kit in in a few days... personally mine took me a good months worth of weekend days/nights. But i spent painful amounts of time on wiring, making sure i had the right gauge for everything, have everything mounted and drawn up incase i ever had a problem. Extremely please with how it came out though, and everything worked flawlessly. (knock on wood lol)
Old Oct 5, 2009 | 07:57 PM
custm2500's Avatar
Ph.D. in HUBRIS
Start to finish the nitrous kit only can be done if a few hours worth of work. I would your first time you should be able to get it done in 3 hours or so. If you install heaters, remote opener, or other toys at 30 min each. I just ran all my wiring and it took maybe 2 hours and that included wires for a window switch.
Old Oct 6, 2009 | 07:07 AM
streetassasin's Avatar
damn dude already have it wired up? Thats badass
Old Oct 6, 2009 | 07:34 AM
TA1364's Avatar
Depends how many things you have to wire up and how comfortable you are doing it. I would plan on it taking a while to make sure everything is right and looks clean.
Old Oct 6, 2009 | 08:28 AM
Ruckus46Gt's Avatar
First time i did it, it took around 5 hours. Last time it took 2 hours
Old Oct 6, 2009 | 08:43 AM
RsSean's Avatar
It took me a good weekend per install, that I have done. All the wiring is hidden, the only things exposed is the noids. It depend on how nice you set it up.
Old Oct 6, 2009 | 10:00 AM
Cape T/A's Avatar
Your car has turbos and your asking how to put nitrous on? WTF
Old Oct 6, 2009 | 10:18 AM
Speed Density's Avatar
hashtagBMW
Read the instructions and keep it clean, probably will take you a weekend the first time.
Old Oct 6, 2009 | 11:41 AM
thanks guys i appreciate the info. when i install it i will be sure to post up some pics.
Old Oct 6, 2009 | 12:53 PM
Mike@HSW's Avatar
entirely depends on what components you get with your kit. Question, how come your adding nitrous to your setup? is this on a stock short block? give us some more details
Old Oct 6, 2009 | 03:12 PM
Chris@NitroDaves
Guest
Posts: n/a
A typical Kit < Single Nozzle or Plate kit w/ Window Switch > can take up to 2Days for install.
A Complete Kit < Single Nozzle or Plate kit w/ Window Switch, FPSS, Bottle Heater, Purge kit, and Switch Panel > Might take up to 3 days
A Total Package < Single Nozzle or Plate kit w/ Window Switch, FPSS, Bottle Heater, Purge kit, Switch Panel, Widewband, Timing Controller, Remote Opener etc... > Can take up to 4days
All the times will ultimately depend on your automotive and electrical knowledge and how fast one works. Time frames also depend on how clean and sexy you want the install to look.
-Chris
Old Oct 6, 2009 | 04:05 PM
jman54002's Avatar
-Chris
take your time you want it sexyyyyy, me 8 hours total kit heater,wet kit plate design.
Old Oct 6, 2009 | 06:13 PM
Ruckus46Gt's Avatar
here is a 2 hour install
then moved bottle up front so guess you can say a 3 hour install cause that took an hour....tunnel mount with one person not so fun
Old Oct 6, 2009 | 06:57 PM
custm2500's Avatar
Ph.D. in HUBRIS
Yep wires are run just waiting for the kit to hit the door at work.
Old Oct 6, 2009 | 08:33 PM
Ruckus46Gt's Avatar
knowing exactly how you want to do everything saves hours in the install.
Old Oct 8, 2009 | 03:33 PM
The block is a stroked 383 ls1 with ported stage 2 ls6 patriot heads, upgraded manifold, cam, pulleys, with the sts turbo with methanol kit and a few other things. can you run nitrous with a meth kit installed?
