fastest way to pull the plugs
what is the fastest way to pull the plugs on our cars, can you pull all of them from the top? coil packs are relocated to the cowl.
and what tools do you use, I'm going to have to start getting good/fast at this when I start to spray
I'm sure there are more than a few "secrets"
Chad
Chad
definitely keeping the A/C gets a tad warm here in the summer. hell all year round.
a search brought up these 2 tools....
http://buy1.snapon.com/catalog/item....re&dir=catalog
http://www.stanleyproto.com/default....e+Head+Ratchet
both look like they could work well.
anyone have any comments?
Chad
Chad
Chad
Chad
even better your coil packs are relocated.a short stubby ratchet for the #7 and #8 from the top and small hands.
1in & 3in extentions, regular ol spark plug socket, and a 3/8s rachet is all you need, and yes since your coils are already moved, it wont be a problem. i can do mine in about 20 minutes
I use a swivel spark plug socket get 7 from the top and the #7 from the bottom, all in about 15 minutes or so, not including gapping and putting never sieze on the threads.
if your coil packs are off the passanger side, climb up in the engine bay, reach back there with two hands and give that #7 a good ol once over. No need to jack up the car
+2. takes me about 45 min working at a normal pace start to finish (remove, gap, antiseize, install). however, my coils are in the stock location
2 1 inch extensions, a swivel ratchet and no ac or hvac makes it pretty easy. I can do plugs in a hot car after a pass in like 10-15. most use a 1 inch extension but a couple plugs you need to hook them together for a total 2 inch extension.
good luck
good luck
Chad
