What to use to cut plugs?
Old Oct 28, 2009 | 05:18 PM
TS6's Avatar
TS6
Default What to use to cut plugs?
So to get a good reading on your plugs you cut the threaded part off, right? The pics I saw looked like really clean cuts, is there a tool made for this? Didn't look like your typical angle grinder/dremel job in the ones I saw.
Old Oct 28, 2009 | 05:24 PM
camscam02's Avatar
die grinder with a cut off wheel, dremmel with a cut off wheel will work. cut below the threads.
some people use a lathe but not many have them.
Old Oct 29, 2009 | 07:07 AM
JL ws-6's Avatar
Race your car!
A lathe would be the best, but like mentioned it's not something alot of people have.
Air tool with a cutoff wheel, that's your best bet. Dremel will do it, but you'll be there a while if you've got a bunch of plugs to do and you'll go thru the disks pretty quick.
Old Oct 29, 2009 | 09:57 AM
ShiznityZ28's Avatar
Easyest at the track is Dewalts 18V battery angle grinder with a 6" cutoff wheel. just enough power to cut but not grab the plug and throw it at your car LOL. a vice would be nice but were not that high tech yet..... vice grips and the cutoof wheel...
the reason the cuts look good is a cuttof wheel will not cut porcelin so it just cuts the metal
Old Oct 29, 2009 | 10:47 AM
JL ws-6's Avatar
Race your car!
Vise in the trailer... (as I make note to add this to the list)
Old Oct 29, 2009 | 02:59 PM
Chris@NitroDaves
Guest
Posts: n/a
What these guys said....lol
Old Oct 30, 2009 | 10:11 AM
Nick@HSW's Avatar
Just watch the heat of the cutting action while doing it.
Nick
Old Oct 30, 2009 | 10:44 AM
Nitro Dave's Nitrous Outlet's Avatar
If you do not have a cut off wheel a hax saw will work but its alot of work..
Old Oct 30, 2009 | 11:22 AM
JL ws-6's Avatar
Race your car!
Lathe is sounding better and better.
Old Oct 30, 2009 | 11:37 AM
Nick@HSW's Avatar
lol next will be cnc mill then automated machinery...its a sickness...once you spoil yourself with a nice lathe it all just goes downhill quickly.
Nick
Old Oct 30, 2009 | 12:09 PM
JL ws-6's Avatar
Race your car!
I have a very small lathe already.. but it's not big enough to really do much with.
I hear ya though. I've been looking for a bridgeport to put in the garage, once that happens I'm screwed
