Piston rings for a small shot?
Old Nov 5, 2009 | 10:52 PM
JRracing's Avatar
Default Piston rings for a small shot?
we are going through the motor over the winter and I was wondering about switching the rings to something more for n2o. We are spraying 100-250 shot through a plate.
The motor is a 383 with diamond pistons and eagle crank and rods. It has hasting moly rings in it now. Would it be worth switching to something differant?
Old Nov 6, 2009 | 07:59 AM
G Engines's Avatar
It will be well worth it to change your rings the molly rings will take it for a short while but it will be short. The heat the nitrous produces will burn the moly coating off of the rings resulting in ring failure. I would recommend to change to an HTD, Xtream ring from Akerly and Childs. Scoggins stocks them they will run you about $160 and will handle all the nitrous you can throw at them. I use these rings in all of our nitrous and FI engines with much better results than any other brand.
Old Nov 9, 2009 | 07:14 AM
JRracing's Avatar
I seen that scoggin dicky has A&C rings. I will look at them later today.
Old Nov 13, 2009 | 12:17 AM
JRracing's Avatar
The Extreme rings at SD are $116. Not bad. What kind of gap would I need to set these up at for this kind of shot? Do they sell them in a 3.905" bore? How does that work?
Old Nov 15, 2009 | 07:47 PM
JRracing's Avatar
TTTTT. Anybody?
Old Nov 15, 2009 | 07:50 PM
G Engines's Avatar
use .006 per inch of bore and you will be good to go 3.900*.006=.023 on your top and i would go .025 on your second 3.9005 bore is common they should have them in stock.
Old Nov 16, 2009 | 09:39 AM
jetblast's Avatar
why is the gap for boost different than a nitrous set-up?... i saw a build with total seal, top ring was .028 and 2nd was .020
Old Nov 16, 2009 | 07:46 PM
G Engines's Avatar
Im not sure who set a ring gap up like that but I would never run that set up. When you run a slightly bigger gap in you second ring it helps to release the pressure in between the rings reducing the risk of lifting a ring land. I also run close to the same gap for a boosted app. as a nitrous taking in account the amount of boost or nitrous shot's.
Old Nov 16, 2009 | 08:49 PM
JRracing's Avatar
Thank you for the advice. It helps.
Old Nov 17, 2009 | 12:55 AM
CamaroRick's Avatar
then how come diamond reccommended .26 top .22 bottom?
Old Nov 17, 2009 | 08:27 AM
jetblast's Avatar
perhaps gap choices are directly related to how far the pin is up. stroker versus none stroker.
Old Nov 17, 2009 | 04:55 PM
G Engines's Avatar
Your ring gap is based on the heat produced on the top ring when you add things such as nitrous or boost the heat is increased requiring a larger gap for ring expiation. I can only give advise on what I have learned from my own personal experiences building engines with multiple stages of nitrous and supper chargers, or what I have read from ring manufactures. IMO that ring set up is incorrect.
Old Nov 17, 2009 | 05:08 PM
sweetbmxrider's Avatar
thanks for sharing the info, it will help me in the future.
Old Nov 17, 2009 | 05:49 PM
jetblast's Avatar
there is no question field experience is worth it's weight in gold. here is the build i was talking abuout.
http://www.enginebuildermag.com/Cont...0000011833.pdf
Old Nov 17, 2009 | 11:14 PM
JRracing's Avatar
The A&C Extream rings are the best value at this point. Is there a web site were I can find out more about these rings? The vendor adds do not tell much about them.
G engines, what kind of motor expierence do you have at building motors? How many years and what type of stuff do you build? Just curious..
Old Nov 18, 2009 | 09:57 AM
jetblast's Avatar
http://www.akerlychilds.com/
http://www.speedtalk.com/forum/viewt...18acbab1fa42bd
here are coulple of links that i found. i'm also researching for my next build.
Old Nov 18, 2009 | 04:32 PM
JRracing's Avatar
Very good info in that thread. Thank you!
