Best cam only with n2o
You should make a hard left at the 1/8th mile .... that thing is a TERD !
The ms3 would get you there no problem if you want a off the shelf VERY popular na or n2o cam the ms3 is a good choice!
Or get patrick g or someone thats credible to spec you a n2o cam...but the easy solution is ms3 It will do good on motor and spray!
Cam , heads , built trans. and a N20 kit to go 10.80
We had a full weight cam only car with 150 shot going 10.50's 3 years ago.
If you shut you coksukr and listen to some guys that have been where your trying to go you may be able get there a little faster and spend less money on the way.
FUKING CLOWNSHOES!
this winter when the car is away I will be adding a 100 shot to make the beast even more of a beast. I just had 4.10 gears installed last weekend and holy ****, they woke the car up even more from the 3.42's!!!
Theirs a **** load of videos of m car on youtube. Idle videos, race videos etc.....racing a few pullied cobra's, 11 second Audi S4's and Honda's. Just jump on you tube and do a search with MS3 Camaro SS. Its white. Most videos are night videos tho.
the cam options you threw up are pretty broad for someone asking for straight forward response, and imo not the greatest specs...
and just to humor you the MS3 is a 237/242 .603/.609 on your choice of 112/113/114 lsa, and as stated a bit higher lsa would be suitable for spray, also the larger duration and lift on the exhaust side would also compliment the spray without sacrificing NA power...
he also stated that he would match his converter to his cam, so a 3600-4k would do fine....and exhaust/weight shouldnt be much of an issue with cam choice while under the curve or high rpm range power curves should be what your looking at, but since he is going for track power, the ms3 again is a good choice
so stick that in your pipe an smoke it..
I don't think im the next anuy thing. But i have ground and raced alot of cams. We had a 3600lb cam only car run 10.5 all day on a stock 10 bolt and 4l60. Not a shelf grind....
When i posted my ideas he did not have any of the info thats why i put it out there. everyones idea of the perfect cam is different some want it supper smoth pulls hard up top for street stuff some just care about 1/4 mile et. he said he was going to daily drive it.
either way i put what i think. i bet you have never had 2 cams with only a few degrees different and know what the difference is.
As far as who you should take advice from. Your choice:
-The guy that's been 8.90 on nitrous
-The guy that's been 10.80 with a 9.90 combo.
hmm...
