Best cam only with n2o
oh neat !
lets break this down. the 1.5 car weighed 3600+ full leather full weight. less than 4K in the whole car with wheels.
no your car probably should not run 9.9 but at least 10.3 with ls6 heads vs stock heads. Your friends cars seem fast. sorry yours is a turd. we also have a stock bottom end stock ported h/c car runs 9.8 LOL.
The point was you probably shouldn't argue cams with only worked on 3 cars(including your "friends") . posting the ms3 was fine but arguing why the ms3 will work on a stock intake ,stock rear,low bolton 150 shot car is just dumb. the guy needs a 5400-6200 rpm band thats long and flat. thats not the ms3.
As for me, I would say if the max you are going to be spraying is around a 150 and you want nice drive ability. A nice 232/238 .60x/.60x on a 112 would work perfectly.
A big cam is not needed to go fast, have a look at Chris1313. His cam is a 230/230 and he's running in the 10's cam only.
My cam works great on the spray 230/236 112, no problems here. I may have slight surging, but that's mostly bc I have such tall gears with my T56.
Congratulations, you just insulted two of the most knowledgeable race-proven nitrous LSx guys on this board.
You, sir, are a winner!
heres my old GTP
Have a nice day Newb.
Ding ding ding! we have a winner.
BTW my 10.0 cam only/nitrous car isnt stripped out at all 3400 lbs and should go pretty deep into the 9's this weekend. Put a set up together correct and it should fly. Your terd should be going bottom 11's on motor alone. but just my opinion.
I will admit right now, with the stock 3.42's, The power band was high. It pulled like a bat out of hell between 4-6800rpms. This didnt bother me, because when your racing you should never be below 3800rpms to begin with!
Then I added 4.10's to my setup and Holy **** did it really wake up the power band. The power is alot smoother, and It pulls the same from 3500rpms-6800rpms....all the way through the power band and the car can launch like a mother. It blows the tires off from a 50 roll to the point it gets squirly and I need to lift.
It all comes down to what setup your planning with...and by setup I mean what gears and what not.
