Pics of Window switches and Relays
Old Dec 30, 2009 | 12:38 PM
Greekey's Avatar
Default Pics of Window switches and Relays
Can you guys post your pictures of your relays and window switches. I need some ideas on where to mount these. Thanks
Old Dec 30, 2009 | 08:12 PM
BlackNightmare's Avatar
Here goes a few of my setup.
you can see the top of the relays to the right of the radiator in this pic just beside the ground screw.
Old Dec 30, 2009 | 09:07 PM
BakaN20's Avatar
Doesn't really help you, I just like whoring my pics, lol
Old Dec 31, 2009 | 10:26 AM
TA1364's Avatar
I put my relays in the glove box and used double sided tape to put my window switch in there too.
Old Dec 31, 2009 | 01:03 PM
Speed Density's Avatar
hashtagBMW
I drilled a hole near the front of the compartment and ran the wires in a loom through there, its pretty slick.
Old Dec 31, 2009 | 01:14 PM
99blancoSS's Avatar
Hide the relays up under the dash. Nitro Dave has some nice switches that fit in that sunglass compartment under the heat/fan controls. Window switch in glove compartment.
Old Dec 31, 2009 | 01:16 PM
Greekey's Avatar
I like that idea but I have a question. I dont know to much about electrical stuff but I heard that a certain length wire can only carry so much amperage. Those wires shouldnt have a problem going to the engine bay correct?
Old Dec 31, 2009 | 01:58 PM
brokenfly's Avatar
too bad the window switch wires do not run out of the back of the controller...mine is folded back as well...
and the display is almost a flash light at night...lol...
Old Dec 31, 2009 | 02:43 PM
hashtagBMW
I dont know the numbers but I usualy do it like this:
If its smaller then 16 gauge from the relay then I usualy go 14/16 gauge wire to wherever.
If its 14 gauge I usualy go 12/14
If is anything bigger like a power/ground then run the same size or a bit bigger.
My kits have all worked with that 'scheme'.
