HSW 90 plate vs. N2Outlet 90 plate???
Looking to switch to a plate, but which one?? Is there really any difference between the 2 or just personal preference?? The HSW has 360* pattern,
N2Outlet does not state. I am not concerned with the max ratings of the two, as I will never reach them anyway. Just wondering why there is a $100 difference between the two.
thanks guys
Kane
thanks guys
Kane
I had an HSW plate, and with my new setup I'm going to a Nitrous Outlet plate. The biggest differences from what I can tell, are that HSW plates are 1" thick where Nitrous Outlate plates are 3/4" thick, the HSW uses a 360° spray pattern where Nitrous Outlet has a different spray pattern for each type of plate, and HSW uses staggered length nitrous/fuel lines to prevent a lean spike where Nitrous Outlet says theirs will not have a lean spike even with equal length lines.
I don't have the nitrous outlet plate in yet and I'm sure it will be fantastic, but I had no problems running a 125 shot through my HSW plate last season.
does anyone have a the video showing the HSW plate in action? I can't seem to find it anywhere and the link on HSW's site for the video doesn't work anymore. I have already viewed the Nitrous Outlet video.
i got the video to work. I had to save the link to my computer, then open with windows media player.
http://www.harrisspeedworks.com/shop.../hsw-plate.wmv
https://ls1tech.com/forums/nitrous-o...st-design.html
https://ls1tech.com/forums/nitrous-o...s-plate-2.html
Those are some, but it is a very debatable topic and could get out of hand real quick.
I am switching because I am switching to a N2O Outlet hard line kit and wanted the cleanest install possible without the risk of a lean spike that comes with the HSW plate unless running a longer N2O line.
I had ZERO problems with my HSW plate, it was just time for a change!
You sure about that? this is on the second page of my search
thanks
Read these links, there is some good info there, especially the first one.
FWIW, I run the HSW plate (wet). I have had great results with it, and the microedge. However, I really would like to try the NO plate on my own car sometime to compare the differences. HSW & NO both seem to have great customer service so regardless of which one you decide on, you'll be in good hands.
