PAGING NITROUS OUTLET - You all offer premade harnesses now?
I just noticed in the latest issue of GM HighTech that you guys are making predone harnesses for nitrous kits. Is that something you'd need the car for, or can it be done via e-mail? Please give me/everyone else details!!
This could be what finally gets my car to not have a rats nest of wires under the center console!
Tell me it's true
Tell me it's true
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
Gotcha.... I may have to give yall a call. Any idea if you'll have anything specifically catered to something like:
Your old two stage RPM & TPS Switch
Stand Alone
Trans Brake
Harlan 2-Step
Heater
Purge
Everytime I wire the damn car it turns into a rats nest... The addition of the Two Step and Trans Brake is going to make it even worse this time....
Stand Alone
Trans Brake
Harlan 2-Step
Heater
Purge
The Harness is designed to work with our digital dual stage windowswitch with built in TPS activation.
The harness will controll the following.
2 system stages
Switch panel
purge
bottle heater
remote bottle opener
fuel pressure safety switch
dedicated fuel system (Break Out)
These production harnesses will be ready to ship in 3 to 4 weeks. We got so slamed with so may projects we drug our feet making a few small changes and the advertisments hit before we got them on the shelf. This is why we have been hush hush about the project until now. WE know other companies like to copy our hard work and innovative ideas.
On another note. We can custom build car harness for a specific application. With the custom harness you recieve a colored diagram of your harness and the harness is labeled for your specifics. Pricing varys depending on what all goes into the harness.
2 system stages
Switch panel
purge
bottle heater
Guys, This took us 9 months to perfect and many different changes due to the fact we wanted a true plug-n play nitrous system. It took a great deal of money to get this done and due to a few small changes we are making last minute so that it can work with both our nitrous controllers it slowed releasing it. I do not have final retail price yet but this will probably retail for around 350.00. Concidering you would pay a shop 800 or more to wire a car with everything this harness supplies I feel it is a smoking deal. Pluss every connector, relay etc is weather tite seals.. You will honestly be able to bolts the system on the car plug everything up and go. This will honestly turn a week long install into one afternoon with the results of a professional.
I feel this is going to be a bennifit for not only the guy doing his own install at home but for a shop performing the install as well. THey will be able to sell the harness to there customer and be able to provide the installation in a portion of the normal time spent wiring a full system.
Since the harness is fully labeled and comes with a schamatic the odds of having a wiring issue at the end is greatly reduced to almost none if any.
Dave
Dave
i have been check your site every now and then but still dont see it up yet, not trying to rush yall but is there any ETA on this. im waiting to install my system till this is out.
