TSP MS4 cam, and spray?
Old Apr 19, 2010 | 05:28 PM
Dirty Vegas's Avatar
Default TSP MS4 cam, and spray?
In the middle of a swap, wondering if I should go all out with a big cam. Would a MS4 work on the gun? I know the G5X4 will work with a hit. Anyone spraying big NA cams?
Old Apr 19, 2010 | 05:35 PM
ryarbrough's Avatar
I've been a 10.0 with mine, no suspension work, and a restrictive elbow... Looking for 9.70's this year now that the issues are fixed
Old Apr 19, 2010 | 05:37 PM
How big of a hit?
Old Apr 19, 2010 | 05:48 PM
ryarbrough's Avatar
175ish... Put 200 on the stock cube list as a more aggressive estimate
Old Apr 20, 2010 | 09:07 PM
gsxr1k2's Avatar
You must be at a hell of a low da.
Old Apr 20, 2010 | 09:34 PM
LUISP's Avatar
can anybody tell me what wire is the tps sensor on a 2000 SS. im installing my nitrous and cant figure it out.
Old Apr 20, 2010 | 09:39 PM
StreetSilverado's Avatar
It's the ugly blue"ish" one.
Old Apr 20, 2010 | 09:46 PM
camscam02's Avatar
id run the x4 over the ms4 if those are your two possible choices, they will all act around the same with nitrous up to that 200ish level. i like x4 specs a lot better the the ms4
Old Apr 21, 2010 | 06:58 AM
ryarbrough's Avatar
Nah. The runs were at Memphis TN. The car just works for some reason
Old Apr 21, 2010 | 06:59 AM
ryarbrough's Avatar
Yeah. It's got WAYYY too much lift on the intake side. That will change soon with a custom cam. Back when I put this thing together I just wanted the biggest donkey dick cam I could find. Now I'm about making the car fast. There will be changes
Old Apr 21, 2010 | 09:14 AM
MS4 cam kit $689. G5X? cam kit $1600. Thats an easy decision.
Old Apr 21, 2010 | 10:05 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
On anything under a 200 shot the cams will act relatively the same. If you are going above a 200 shot I would recommend getting a nitrous specced custom cam. Give us a call and we can get you taken care of.
Old Apr 21, 2010 | 10:55 AM
miller456's Avatar
Heres a 150 shot with the ms4 on a mustang dyno
Old Apr 21, 2010 | 07:18 PM
conde'strans's Avatar
Damn I woulda figured higher numbers of this combo. I need to dyno my MS3 with the 150 see what it puts down.
Old Apr 21, 2010 | 07:44 PM
camscam02's Avatar
9.86 139 on a 150 shot at 3400 lbs on stock heads. It will make good power if you know what you are doing.
Old Apr 21, 2010 | 09:57 PM
Wow nice! What cam was that on?
Old Apr 21, 2010 | 10:04 PM
blwn_00gt's Avatar
wow more details please...
Old Apr 21, 2010 | 10:08 PM
camscam02's Avatar
heres the thread with all the details etc.
https://ls1tech.com/forums/nitrous-o...yup-i-did.html
should go 9.50s here soon with the same setup.
Old Apr 22, 2010 | 01:27 AM
blwn_00gt's Avatar
^^^^very impressive...
Old Apr 22, 2010 | 12:00 PM
miller456's Avatar
You also understand this is a mustang dyno right? the numbers are going to be lower b/c the dyno applies a load to the car as if you were driving unlike dynojets where your just on rollers. Also i shut the spray off at 6100 and spun the car to 6800. If i decided to spray farther it would have put down more. I ran numerous 600+rwhp cobras according to dynojet numbers and pulled away from them and they were decent drivers
