TSP MS4 cam, and spray?
I will not post on this tread again,but that's just plan *** crazy!!
Edit; Again I ask...give us your engine combo that made 435 rwhp cam only.
ms3 cam, prc duals
home ported fast 90/90
SSRA, gm 85mm maf, 85mm Fast toys lid, smooth bellow
Pacesetter longtubes 1 3/4 custom dyno max duals
Underdrive pulley, no a/c
Just a bunch of junk
What else are you gonna come on here and say? the calculator and math formulas said its not possible and you yourself dont believe it can be done? So therefore Its not possible and Im a liar?
ms3 cam, prc duals
th400
FTI converter
9inch with 3.89s
28x10.5S
yes 3392 with driver, verified by corner scales.
ms3 cam, prc duals
No bench racer here...I started drag racing long before you ever thought of it!!
Either put up or shutup SONNY, because I have nothing to hide. As for the math comment, guaranteed Ive took more math and know more then you can even think about.
[IMG][/IMG]
So,I'll ask everyone out there this question. This guy's 3400# car was making approximately 500 rwhp based on the set up "he" discribed.. How many of you guy's with approximately 500 rwhp and a car close to 3400# have run 140 mph?
My car makes 606/589 when running the 175 shot with 975 psi bottle pressure and the car weighs 3490 with me in it. My best MPH through the traps is 138.64 which is just about dead nuts based on HP/WEIGHT ratio for a 1320' run.
This clown must think that everyone out there just plain stupid. If he is capable of running the numbers he has stated then it wasn't with 500 rwhp in a 3400 # car!!
Get off the Ricer hp calculators because there are way too many factors to effect those, along with dynos and well thats another story. You have no idea what you are talking about and I actually feel bad for you. You have listened to shops and uninformed people feed you BS and you are stuck in the ,hp to weight to times to calling BS, bubble.
What can DA effect? mph. what can a converter effect? mph. What can rear gear effect? mph. Is your "special" math calculator using any of this? I think no, please do some reading before trying to talk to people who go way over your head with knowledge. Ive been doing this for 21 years and we KNOW what we are doing and you DO not.
The funny thing your 383 with a bunch of crap parts makes 606 on a 175shot.... 606-175= 431 hp on motor???? out of a 383??? hahahahahhaha. Time to pay a different shop to build your car. Hows my math on that one?
Just step away from the key board and learn a little bit before trying to come on here and call BS. Dont blame me your car cant run the number. ****, give me your motor and Ill show you how to do it. Because that thing is WEAK. Even makes less on motor then my CAM ONLY car.
Have a good day ricer and hopefully if you reply you start showing some knowledge and respect. Thanks.
The only rebuttal coming from you is to shift the focus over to anything other than the subject at hand,and why is that? It's because you don't have a clue about what it actually takes to produce the number...140 MPH trap speed. The only person lacking knowledge on this tread is you. So go spread that ridiculous bull **** you claim as fact to rest of your surfer buddies,because their the only one's on this entire forum stupid enough to believe it.
I don't intend to post on this tread again. Can't see wasting anymore time with some jive *** like you.
What do I know? hmmmm lets see, I actually have a car that goes 140 mph unlike someone like you who uses calculators to tell someone they are lying. Yes a calculator. I actually put this setup together myself, put on everything myself and partially tuned the car myself, and then again I know nothing. You are fool.
I dont need a rebuttal because I have nothing to hide, Sorry your calculator couldnt match up, but us, being in the REAL world, know that is the case most of the time. If it wasn't, we would all be dyno, bench, and calculator RACERS like yourself. Go grab a book or experience and get some knowledge because you dont know jack **** about the real world.
good day sir, and remember you are more then welcome to come see the car yourself, I dont hide behind the interweb, myself and the car are known all over and would be damn happy to kick you in the *** in person.
http://www.youtube.com/watch?v=Sk3Pn...layer_embedded
And running 9's with an untouched 346 with a cam and a 150 shot is insane. I looked everywhere on this site and others. A lot of well built cars with more motor, and more spray running those times/mph at the same weight/60ft. Your spray MPH is very high.
Obviously this is not an average ls1 setup. Hence why so much attention.
But I'm curious though. You said before '' hard work'' is why it performed so well. What exactly are you referring to? I know I can speak for many people when I ask this. Because you obviously have a recipe for success. And some of us may want to have a similar setup, Of course. Congrats on the times though. However you did them, they are very fast for sure.
ps. Why have you not gone with a good set of heads, better intake, or whatever? Are you trying to set a cam/nitrous only record?
As for not going to different heads, I am in college working towards my mechanical engineering degree, I dont have a lot of money to waste on the car and the intake setups/heads I would want cost in the 4k range together and thats not in the budget. Soon we will be doing a pair of our own ported/valved 243 heads and see how they do, on a budget ofcourse. Its a budget car with a alot of drag racing experience and knowledge behind it. It will go faster and I have nothing to hide. Everybody I know can attest for the car and thats a ton of people.
Damn,you are without a doubt the only mechanical,electrical,or metallurgical engineer that I have conversed with throughout my career that spurns mathematics and physics referring to them as not being real world!!
The numbers used to calculate the required HP/WEIGHT ratio to produce a given MPH in a 1320' run is pure physics and the mathematical equation used coverts those numbers into real world terms. The numbers produced are not even remotely related to any numbers (HP/TQ) associated with a dyno pull. So the HP required to run 140 mph at a given weight is not based on my personal bias,but is rather a fact of science. The only way these number could not be considered factual (within an allowable tolerance) is if the facts present are totally without merit,thus the claimed performance will not correspond with the required power necessary to achieve that goal.
