shutting car off early to read plugs?
Old May 10, 2010 | 02:19 PM
6point7s14's Avatar
Default shutting car off early to read plugs?
I am running a th350 trans and was wondering how u guys do your cars when u are gonna read the plugs?
Kill the car in gear and coast? (Doesn't sound good)
Or decelerate and shut car off after getiin of track?
How do ya'll do it?
Old May 10, 2010 | 03:06 PM
BAKED's Avatar
As soon as I ross the finish line I click it into neutral and shut it off and coast off to the side and wait for one of my buddies to pull me back with the 4 wheeler.
Other times I have just carried a couple of plugs in the console and changed them myself at the end of the track.
Old May 10, 2010 | 03:19 PM
6point7s14's Avatar
But isn't shifting into nuetral a big no-no? I have just read where everyone says don't do that.
Old May 10, 2010 | 04:57 PM
blu byu EH's Avatar
Yeah i read that too but as long you don't do it all the time you will be fine. a few times shouldn't hurt that much. IMO
Old May 10, 2010 | 06:31 PM
N2RACINGLS1's's Avatar
Well I will share with you what Carl Rossler told me. He said " do not put your car in neutral after crossing the finish line because it sends the transmission into hyper drive causing damage to the internals". Carl even encouraged me to go with a reverse valve body to keep me from doing that.
N2
Old May 10, 2010 | 06:48 PM
magnum-gto's Avatar
Do not kick it into neutral.
Coast to stop and shut it off. Tow it back to the pits.
If you decide to pull the plugs on the return road...
let the tower know your plans, so they don't think you broke something.
Old May 10, 2010 | 08:35 PM
6point7s14's Avatar
I won't shift into nuetral. Ok. Next question. Say I pull a couple plugs and change em on return road and drive back. Which are the best couple of plugs to pull? I'm using a plate system thru a fast 90/90
Old May 10, 2010 | 08:42 PM
n2ocamaro's Avatar
I have been curious about this too as I will be stepping up my shot this year to 200. Is it hard to steer the car after you shut it off?
Old May 11, 2010 | 06:34 AM
ShiznityZ28's Avatar
just leave it in high gear and let it coast. once he cars mph is lower 50 or so then shift to nutral to make sure you get to the turn off. we pull back now but before we had a 4 wheeler we just changed them at the end of the track. header wrap helps with this and good gloves.
Old May 13, 2010 | 12:32 AM
Nitro Dave's Nitrous Outlet's Avatar
As far as which plugs to pull. Every engine is different. You need to learn your motor. Start off pulling all 8 until you locate the cylinder burning the hotest. Then start pulling that plug and a different one or two others each time. Keep in mind as you move up in the hp range you may spot another cylinder burning hoter due toi distribution.
Dave
Old May 13, 2010 | 07:43 AM
6point7s14's Avatar
^^ thank u. That's kinda what I was figuring. Guess I'll just tow it back with a 4 wheeler. Thanks again
Old May 13, 2010 | 07:46 AM
BAKED's Avatar
I have heard that it's a big no, no to shift into neutral but by the time I heard that I had already done it about 50 times without any problems. It must be because of my super high dollar transmission LOL. It's a stock case glide that was built in 1990 for my dads bracket car by a local guy. I changed the fluid in it when I brought it home since it had been sitting since 1993. Put my converter in it and haven't had a minutes worth of trouble!
If the experts say to leave it in high gear then that is probably the thing to do, I'm just tlling you about my experience.
Old May 13, 2010 | 09:06 AM
Dragman's Avatar
^^ thinking he is talking 4l60E's not powerglide as guy's always do that to them.
