Truth about nitrous effects on pistons.
I know that under correct timing, CR, AFR, tune, etc a turbo car's pistons can last very long, won't slowly tear them apart. Is this true for nitrous? From my understanding, nitrous is basically just oxygen, basically a chemical turbo? But it's a violent reaction.. So can you set, for example, an ls2 goat up with a 150 shot and it not slowly develop holes in your pistons? or is there simply no way around it with nitrous.
Thanks,
Ricky
We have a dipshit at work that preeches dope destroys pistons and its stupid to run it on/in your car. There is no arguing with his old bastage *** either becuase he is ignorant to understand the real affects.
The best part is you can drive all day NA putting very little stress on equipment. Then with the flick of a switch and with the proper electronics you can spray the crap out of it safley!!
prolly later down the road im a get a progressive when i go into bigger shot range
Hoping for 550rwhp & 10's. :]I DD a 320k mile 1998 firebird. Lol, it's falling apart, I need a new DD. It's gonna be LSX. bolt ons and 150shot is the setup I was gaining for.
Some basic rules of thumb on Nitrous:
1. Retard ignition timing by 4-8 degrees (1 to 1-1/2 degrees timing retard per 50 HP gain)
2. Be safe and use better fuel on nitrous. Anything above say 125 shot use some 100octane to be safe. I used 125 on pump gas all the time with no issues
3. Don't user nitrous for more then say 15 seconds. Nitrous creates increased cylinder pressures which caused a lot of heat. With lots of heat you can cause pre-ignition or worse full detonation. The longer you keep the juice on the hotter the motor gets until things are glowing red hot and you jump into full detonation and KABOOM!
4. The hypereutectic pistons that come stock in a lot of cars are really hard and don't like detonation at all. They aren't forgiving at all will shatter if full detonation occurs.
5. Check your spark plugs often and consider a colder plug.
6. Nitrous should only be eneabled above a certain RPM (say 3000) make sure you have an RPM switch to enable it. Having nitrous backup into your intake can cause a nasty bang. A guys hood almost landed on my car once on a drag strip run due to that.
7. Nitrous tends to shock your drivetrain. Make sure you have the hardware to handle the power.
I went Turbo because I loved the power all the time and it seemed like I was running out of it way too often.
Make sure you have a Fire Extinguisher handy also.
http://www.youtube.com/watch?v=JYAI0rwRsbU&NR=1
http://www.youtube.com/watch?v=-1cPuJza_Aw&NR=1
Here's a link to some pretty good information:
http://www.gmhightechperformance.com...ely/index.html
You should post your v6 buildup in the FI section if you havent and get some pictures too, now there is a good thread to start...
