125 to 150 with pic need help fast
Old May 23, 2010 | 09:50 PM
mikemunoz's Avatar
Default 125 to 150 with pic need help fast
my mods r in my signature and the car is on a nitrous tune. i have a 125 shot in the car right and have no problem at all with it, but want to move the 150. u think it will be ok, sorry for not enough info. and i dont know what the A/F is at but u can smell it running rich bad. any info will help here r the pic
plug 3
plug 4
plug 5
plug 6
plug 7
why is plug 4 half and half, y is plug 6 and 7 all wet? y r all the others look good need help
Old May 23, 2010 | 10:42 PM
nysbadmk8's Avatar
Pull your plugs and read them
150 should be no issue... but knowing your A/f's and having the correct amount of timing removed is the best way to go about this.
Old May 24, 2010 | 06:40 AM
dnkynrbk's Avatar
Get a A/F wide band in your car. The one with the sensor that goes in your exhaust Its worth the $150 for the gauge vs a blown motor. Running rich can destroy your pistons to. Do you have someone that tunes your car?
Get a #7 NGK plug non projected.
Old May 24, 2010 | 12:40 PM
mikemunoz's Avatar
Here is more info on my car it is at 24* timing and its on a nitrous tune, but that tune was done to it on stock fuel pump and stock 26 pounds injectours running at 116% duty cycle. Now I have added the walbro 255 and the red top svo 30 pound which is 36 pound to f-bodies and I got an injectour tune so I can run right. After the injectour and fuel pump swap I got an 30 miles more out of a full tank. Don't know if that help. I'm running ngk tr6 gaped at 35.so any help on my dilemma
Old May 24, 2010 | 01:30 PM
ShiznityZ28's Avatar
what fp and what jets?
Old May 24, 2010 | 02:55 PM
LS1Z28-00's Avatar
with all the mods you have and im assuming the A/F has never been checked, i would get that thing to the dyno. whats 300 bucs compared to a new motor, especially since your spraying it. running rich is better than lean but still not ideal, your leaving some power on the table.
Old May 24, 2010 | 03:44 PM
Chris@NitroDaves
Guest
Posts: n/a
I would check the AFR before going up on the shot just to be on the safe side.
Old May 24, 2010 | 05:21 PM
mikemunoz's Avatar
the FP is at 68 the jets are NOS 68N AND 38F. WHAT IS RECOMENDED FOR THE A/F SHOULD BE AT FOR THE 150 SHOT. SORRY FORGOT TO SAY ITS ON A SPEED DENSICTY TUNE RUNNING OFF THE MAP SENSOR
Old May 29, 2010 | 06:12 PM
mikemunoz's Avatar
ttt need help
Old May 31, 2010 | 09:57 AM
kidcamaro98's Avatar
do NOT run tr6's anymore.
you want to run a BR7EF non-projected plug. Running a TR6 on a 125 shot or a 150 will eventually be bad news.
Your #6 and #7 plugs look like you have some pretty bad detonation going on.
24 degree's of timing is too much IMO to run a 150...you should be more in the 21-22 area.
Im not no nitrous Guru but I know the basics. Maybe someone else can jump in with some better info.
Old Jun 1, 2010 | 09:53 PM
mikemunoz's Avatar
so what should i gap BR7EF and who makes those plugs
Old Jun 1, 2010 | 10:24 PM
dnkynrbk's Avatar
Gap 32 NGK plugs you can order them thru Nitrous Outlet or a tech sponsoner im sure. I would get a box. Look like your timming is to high and you do have detonation going on. I would not go up in shot until you get the A/F lined out first.
Old Jun 2, 2010 | 12:23 AM
mikemunoz's Avatar
so what would be a good A/F to run the 150
Old Jun 2, 2010 | 05:12 PM
Chris@NitroDaves
Guest
Posts: n/a
We like to run the AFR @ 11.8
Old Jun 2, 2010 | 06:47 PM
dnkynrbk's Avatar
I would put in fresh plugs before you spray. When you are getting the A/F lined out
