{:o)
Old Jun 12, 2010 | 12:35 AM
=ZoomZ='s Avatar
Default {:o)
Its a nice clean one off i made , wadayathink ?
And it will support about 1400hp worth of nitrous and can be made to fit on any manifold
Old Jun 12, 2010 | 02:47 AM
Speed Density's Avatar
hashtagBMW
Yea, thats legit. I like how you have the noids mounted on the radiator shroud.
Old Jun 12, 2010 | 08:14 AM
custm2500's Avatar
Ph.D. in HUBRIS
You forgot to paint the battery and all that nitrous junk black!
Just messing around. Looks Good and fast!
Old Jun 12, 2010 | 09:43 AM
=ZoomZ='s Avatar
oh yea , i forgot to say , "patent pending"
Old Jun 12, 2010 | 11:17 AM
custm2500's Avatar
Ph.D. in HUBRIS
There is someone who makes black braided lines.
Is there a plate and a DP?
Old Jun 12, 2010 | 12:46 PM
=ZoomZ='s Avatar
yea , 150 HSW plate and a 150 dp .
Old Jun 12, 2010 | 03:59 PM
=ZoomZ='s Avatar
Its so much easier than trying to bend all the tubing needed for a dp kit .
Old Jun 12, 2010 | 05:22 PM
RsSean's Avatar
That is pretty neat way of doing a a direct port. Way to go!
Old Jun 14, 2010 | 03:33 PM
ShiznityZ28's Avatar
I bet it cannot support 1400 hp worth of nitrous.... prove me wrong
Old Jun 14, 2010 | 03:49 PM
ryarbrough's Avatar
Are you stacking plates on the front? How much do you really expect that to support?
Old Jun 14, 2010 | 03:57 PM
=ZoomZ='s Avatar
Based on numbers , not reality silly ,, lol
it will support .076 jets on 8 cylinders with a 1/4" through rail hole being fed from both directions with 4x.125 noids @900 psi of nitrous and 45 psi of fuel .
I always quote a conservative number of 1400hp flow rate
Results
The Fuel jet size should be 0.042" or 1.061mm
A Nitrous jet size of .076" or 1.9304mm should produce:
2086.81 HP with 8 port(s)
Actual HP to the wheels: 1773.79 HP
Its a single HSW plate with 150 jets and the DP has 150's in it also .
My motor will only handle 300-350 max .
The silver block mounted on the HSW plate is a distrubution block for the DP .
Old Jun 14, 2010 | 04:05 PM
Chris@NitroDaves
Guest
Posts: n/a
Not bad at all
Old Jun 14, 2010 | 04:14 PM
ryarbrough's Avatar
Gotcha. That's a pretty trick way of mounting it.
Old Jun 14, 2010 | 04:23 PM
Nitro Dave's Nitrous Outlet's Avatar
Creative thinking.. Nice work.
Old Jun 14, 2010 | 05:56 PM
=ZoomZ='s Avatar
Originally Posted by Chris@NitroDaves
Not bad at all
Thankz Dave and Chris .
That stainless tubing that comes with the direct port kits was kicking my butt , so i sat down and designed this setup instead .
The possable applications are endless and this design willl lend itself to any intake manifold out there , making installation clean and sexy.
Thats why i filed the patent pending
Old Jun 14, 2010 | 06:12 PM
repo's Avatar
you selling these yet?
Old Jun 14, 2010 | 06:22 PM
=ZoomZ='s Avatar
I cant sell anything on the forums , its against the rules .
Old Jun 15, 2010 | 08:50 AM
jmm98LS1's Avatar
Clean install. Looks like it's a real b*tch to change jets on the fogger.....have to remove all the rails to do it?
Old Jun 15, 2010 | 09:41 AM
=ZoomZ='s Avatar
Naa , bent wrench is easy enough .
You do have to take all 4 nuts off at one time and lift up on the rail but its not a biggie .
Ive never seen an LSx that was easy to change jets on .
