What caused my plug to look like this?
Old Jul 12, 2010 | 10:57 PM
kidcamaro98's Avatar
Default What caused my plug to look like this?
I just did my first full plug change sense I have been dyno tuned on the bottle (Went through 3 bottles, on a 100 shot so far)...well, my rear passenger plug looked much different then all 7 of the others...These are BR7EF's gapped at .036
Obviously, im talking about the darker one.
Now, I DO know about reading plugs. I know my idle is rich (by the carbon build up on the plug edge), and How to read the timing marks (which seem to be dead on) and what not...but, what would cause this ONE plug, to seem to be running much richer then the others? When I was getting dyno tuned, We did have a problem with my fuel solonoid sticking shut and Im wondering if we fouled the plug during one of those pulls, and then every sense it has been dead. I am not sure. But the car runs HARD on the bottle, and runs great N/A
any idea's? Also, both of the rear plugs had a good amount of oil on the threads...Plugs were in the car for around 2k being DD driven and 3 bottles worth of track/street play.
Old Jul 12, 2010 | 11:07 PM
camscam02's Avatar
Oilllll
Old Jul 12, 2010 | 11:17 PM
Originally Posted by camscam02
Oilllll
such as from what? Bad valve cover gasket? (it is leaked because I have light oil build up on the rear of the valve cover and on the gasket edges all around) or my PVC setup? My motor only has 30k on it.
Old Jul 12, 2010 | 11:29 PM
02 BLK WS6's Avatar
Not a valve cover gasket. It's from one or a combination of three things. Valve seals, rings, and PCV system. I doubting PCV since it's only one plug.
Old Jul 13, 2010 | 01:51 PM
damn.
I only have 20k on my setup sense the cam/valvetrain install which were all professionally done by a sponser.
Old Jul 13, 2010 | 02:29 PM
nitrobasher's Avatar
I'm really not sure about this, However I thought I read somewhere that the #8 cylinder is always a bit more rich than the others?
Anyone have any input?
Old Jul 13, 2010 | 03:00 PM
I also heard this as well.
The car doesnt seem down on power or anything. idles great, drives great, Pulls hard on motor and pulls harder on the bottle. Doesnt blow any smoke N/A or on the bottle, but it does burn oil...but that could simply be because I have a ported LS6 oil pump and am just running the stock ls1 pvc setup into a junky ebay catch can.
Old Jul 13, 2010 | 04:13 PM
98RedRocket's Avatar
hmmm i dono it doesnt look like oil to me looks like that sucker got burnt......hmm smell ur exhaust with the car running. have some one rev it while u stand back there and see for any signs of smoke. rub finger on the inside of the tail pipe and see/smell for oil. might have to do a compression test on her also.
Old Jul 13, 2010 | 04:51 PM
I constantly check my exhaust tips everyday. The only thing that comes out of them, is condensation. There is 100% No oil going out my exhaust.
as far as my car smelling, it naturally smells because I dont have any cats and only have bullet mufflers.
Old Jul 13, 2010 | 04:52 PM
Johnnystock's Avatar
I change my plugs after a bottle and a half. i'm pretty sure if i wait after 3 bottles, it'll look like this...but still, all my plugs look the same...
Old Jul 13, 2010 | 05:08 PM
right now I have tr-55's in there because Im taking my car to myrtle beach thursday which is a 920 mile one way trip. I will pull #8 plug on my N/A plugs and see if it still looks like the nitrous plug...
Old Jul 13, 2010 | 07:08 PM
camscam02's Avatar
It's oil, prolly a ring or valve seal problem if I had to guess.
Old Jul 13, 2010 | 08:46 PM
how can I tell if its a valve seal? just do a compression test and if it comes out good then its the seal?
Old Jul 13, 2010 | 09:17 PM
V-10 Killer's Avatar
I'm trying to remember exactly what I read, I think it was a Hot Rod article on leakdown tests. put it TDC, pressurize it, and have someone listen at the throttle body (cracked open), and at the tailpipes. That will give you a hint if it's a valve leakby issue. You could also pop the radiator cap and check for bubbles, anything not the above could be piston leakby.
Old Jul 13, 2010 | 09:43 PM
02 BLK WS6's Avatar
Replacing a valve seal is simple for anyone with mechanical abilities. Being that it's a rear cylinder is tougher than the other cylinders, but still not very difficult with the right tools.
Good luck
Old Jul 13, 2010 | 10:07 PM
chevysten's Avatar
I would just put new plugs in it and call it a day!You say it runs good n/a and on the bottle,your probably fine.Maybe when that plug was installed might have got a little oil on it.JMO,Mike
Old Jul 13, 2010 | 10:15 PM
yah like I said above, I put brand new tr55s in it just for now because thursday I am taking the car on a 920 mile one way road trip...so, Im thinking the real test to see if it is a actual cylinder issue will be when I get down there, I will pull that plug and see how it looks..
BTW, I put tr55's because my bottle is empty and I wont be filling it again for a month or so...so when I go back to running n2o, I will get all new br7ef's.
Old Jul 13, 2010 | 10:18 PM
Good luck
I am in no means worried about it. I built a turbo camaro in my driveway out of home tools by the age of 18 lol. I also took auto tech for 3 years and have my mechanics degree....just was never taught about replacing valve seals for some odd reason.
Old Jul 14, 2010 | 05:39 AM
BLK02WS6's Avatar
They may have nicked a valve seal on that cylinder when they installed them... have someone watch the exhaust when you start it after having sat for an hour or so... if there is a little puff of white/gray smoke right when it fires, that's a valve seal leaking. Easy fix by putting air to the cylinder and pulling the springs... replace both on that cylinder.
Old Jul 14, 2010 | 07:30 AM
ok thanks guys. I will look into it.
