E85 and n20? Anybody here?
Methanol corrodes aluminum pretty quick, so you'd probably want your intake ports annodized. Also need to make sure you have the right type of seals, as it will degrade certain types.
E85 is less efficient than regular gasoline (higher octane but lower BTU (chemical energy) per volume) so you need to pump in nearly 40% more volume to get your AFR right (E85 stoichiometric fuel ratio is closer to 9.7:1)
Here's a good link to read:
http://en.wikipedia.org/wiki/E85_in_standard_engines
will be back on it soon enough...
anyhoo,i tuned it to the same AFR as i ran on gasoline,motor or spray...
Methanol is corrosive. But please e-85 is ETHANOL not METHANOL!!!
Ethanol will not corrode your fuel system or any al. part. Please do not spread false info on ethanol, it's helped corn price greatly and my family is actaully making a buck for once
FACT: Yes ethanol is corrosive, but not very much. Gasoline is corrosive too. Ethanol is biodegradable in water. So it has a tendency to contain and attract water. It is not the corrosive properties of ethanol that can cause damage to your vehicle; it is the water which can rust a vehicle’s fuel system from the inside out. Today’s vehicles (since mid 1980s) have fuel systems which are made to withstand corrosive motor fuels and rust from water. Also today’s distilling processes are superior to way back when. We now have better techniques for drying out ethanol or reducing the water content.
One other potential consideration in choosing ethanol for fuel:
Making fuel from the food supply can deplete the soil and increases the price of food. While it is easy to replace nitrates with fertilizer so plants will grow, it does not replace the minerals in the soil. Because of this, conventionally grown grains and vegetables these days have a mere fraction of the mineral and vitamin nutrients they did 30 years ago. For this reason, I don't personally support ethanol from corn or other foods. However, I heartily support the ethanol from trash technologies that are emerging.
Last edited by speedtigger; Jul 20, 2010 at 12:06 PM. Reason: Remove argumentative comments and stay on topic
*Edited* removed reply to comments.
89ROC-Z - I don't think you were in the wrong, nice car btw!
