$999 Direct Port Installed
Is this the only option from NX if I am not running a MAF? Didn't see a plate kit for a ls1 on your site? Going to be running a sheetmetal tube instead of a lid setup.
Also I would like some info on that threottle body. Looks nice but can't find it on your site? Just a stock 78mm tb replacement?
The throttle body is a trick piece we made. Its 85mm and comes with a reducer to make the transition smooth on the intake. Were letting them go at 250$ which is VERY cheap for what we have in them. They are not a cheap piece at all.
can you do this set up with the bigger solinoids on a fast 102 intake??
Thanks for all the inquires. I appreciate how well the forum has taken to NX being back here.
