Dynotune install easy?
Old Jul 28, 2010 | 09:19 AM
supersick99z's Avatar
Default Dynotune install easy?
I already have the bottle mounted and gauge put in just gonna get the dynotune dry kit that's like 189.00 and their purge kit. It comes with instructions but my question is, is it pretty much dummy proof with knowledge of wiring and all?
Old Jul 28, 2010 | 09:52 AM
Super Speed's Avatar
Its pretty easy to set up do you have a window switch?
Old Jul 28, 2010 | 01:30 PM
No just what it comes with. The WOT mircoswitch
Old Jul 28, 2010 | 03:24 PM
Chris@NitroDaves
Guest
Posts: n/a
Being a dry kit it will be fairly easy to install. One thing to take into consideration is make sure you make good connections and all power and grounds are good ones.
Old Jul 28, 2010 | 07:45 PM
Will do! Thanks!
Old Jul 28, 2010 | 07:54 PM
OnYoGooch's Avatar
Originally Posted by supersick99z
Will do! Thanks!
Im in the process of installing mine.
Use these for a solid ground
http://www.popularmechanics.com/cm/p...ound_large.jpg
Also, I believe you'll need like a 30 amp fuse for the connection to power.
Old Jul 28, 2010 | 07:55 PM
Yeah I use ring terminals on all my grounds for my wiring no matter what im doing! makes it soooo much easier
Old Jul 30, 2010 | 02:19 PM
Chris@NitroDaves
Guest
Posts: n/a
Will do! Thanks!
Your welcome
