View Poll Results: Which to do first???
Cam
26
54.17%
Spray
22
45.83%
Voters: 48. You may not vote on this poll
Cam+spray guys, if you were to do it again....
What would you do first the cam or spray??? The set up I've wanted to do ever since I bought her and after some research was putting a cam in and spraying I'm in need of some modding soon since my bro bought a terminator and I'm having a hard time deciding which mod to go with first. He's just got an exhaust and CAI but I'm sure he'll be putting in some pullies in the next few months so I'd like to give him some good competition. I've been almost full bolt-ons for a while and I think it's the perfect time to do a little upgrade
Id make sure the rest of your driveline can handle the spray. Clutch, rear, etc.....Also depends on what you plan to use the car for, digs, rolls......I love having the cam and having the power all the time not just when the bottle is full and recently the price of N20 has gone up so ive been lazy getting my bottle filled. Its a blast when you need it but pain to get it filled sometimes, plsu there is nothing worse then getting your *** busted because the bottle is empty. You cant use the ricer excuse either when it happens lol.
If you dont think youll have money for a while after a cam then do spray first since itll be more bang for your buck.
My suggestion is always buy a part for the future, not for the moment. Been there done that and then bought the new part I really needed. Good Luck!
Damn I had the same exact list except I'm currently stuck on the built trans/converter. If your drivetrain can handle it(no 10 bolt lol) I'd go with the spray first. It's not permanent power but it's a lot more "bang-for-buck," much easier to install and the gains are much greater(when you actually need it).
[QUOTE=Carter01;13684730]My suggestion is always buy a part for the future, not for the moment. Been there done that and then bought the new part I really needed. Good Luck![/QUOT
^^^Yea when I first started research on the forums I learned this and it really is the best tip you can get which I've been doing. I just put in a built tranny and a stall to compliment the cam I'm going to put in in the fututre. My drivetrain should be fine besides the 10 bolt. Just don't know what I want to put in first
It was really a 50/50 for me. the cam, if youre going with a big one, has other things involved. like driving characteristics, and awesome sound. spray will behave mostly the same either way.
Yea I'm really 50/50 with the decision. The cam that I plan to put in is the one you've got so it's not too big and will hopefully tighten up and work really well with my converter.
keep in mind if you do a cam you'll be looking at some money spent on tuning. if you want the car to idle right and get full power from the cam your going to need tuning so factor that in. i just did a cam, lt headers, exhaust, plate kit, dry shot, 60lb fuel injectors, plugs, plug wires, ls7 clutch, ls2 flywheel, and alll the supporting mods for a cam, such as a new oil pump, push rods, dual springs, ti retainers, and the car made almost 400 on motor and over 500 on spray
i guess im not much help... i did all of that at the same time. i can see why its a hard choice but both have there ups and downs. do the nitrous first and then when you get your cam you'll be ready to get your tune.
