My NX Fogger pictures........
Well i never got around to posting these, still in the process of finishing the nitrous setup. Gonna start out with the 150's and see how the motor likes it, then move on up from there! Disregard my belt about to fall off!
![](http://i34.tinypic.com/xbwxsw.jpg)
![](http://i38.tinypic.com/t7my6d.jpg)
![](http://i38.tinypic.com/2h6rcet.jpg)
Haha don't worry, itll see the 200's!
Thanks you sir, i appreciate it. Ill be ordering some different jets from you guys soon!
Thanks man!
Nah, its getting a standalone. Thanks!
Thanks you!
Thanks man!
Thanks you!
I just pull my intake off to change the Jets. So they will not fall behind or get lost. I relocated my batter to the back where the spare tire is and built a bracket to fasten it down. I also installed a kill switch thru the rear tail light. Just depends on your goals. If you do the battery in the back just make sure you put 2 ground wires back there.
Thanks you sir!
Actually putting a Rossler Th400 in the car with a Chance converter at the moment, used to have a built 6spd. Really the goal is to trap around 140+ at a 3800lb race weight.
Yah, definitely easier to change jets pulling the intake. I plan on mounting my bottle where the spare tire is, not completely set on this, maybe on the trans tunnel.
