Posible for car to run better NA with N2o
Old 08-30-2010, 11:23 PM
AChotrod's Avatar
Default Posible for car to run better NA with N2o
Swapped my plugs for some NGK BR7efs gapped to .33 for spray and seems the car sceams at WOT better.Than the NA plugs. Am I crazy or does the car just like these better?? Had autolite 104s b4 that looked fine when I pulled them.
Old 08-31-2010, 05:41 AM
SargeZ06's Avatar
Might have been your problem right there. I wouldn't put Autolite in my lawn mower.
Old 08-31-2010, 07:12 AM
dnkynrbk's Avatar
There could have been a fouled plug sometimes you cant see if a plug is nipped or bad .
Old 08-31-2010, 11:36 AM
AChotrod's Avatar
I mean the car ran good b4 leaving at 4500 off the 2step with a 1.68 60ft it went 11.6@120. Just seems more crisp now and like it revs faster.
Old 08-31-2010, 12:45 PM
87silverbullet's Avatar
Never had a problem with autolites. I ran them in my buick T-type on 25lbs of boost with no problems. They are easier to find than NGK's also.
Old 08-31-2010, 01:37 PM
Detroitmuscle's Avatar
my buddy swapped over to TR6s on his cam only LT1 and said the car ran much better as well. that was over the TR-55s
Old 08-31-2010, 02:38 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
May sound dumb, but its amazing how many people wont get a good seal on spark plug boot and run around on 7 cylinders. A local guy ran around after a cam install for about 1 1/2 month and wasent very happy... Does a plug change and realized the issue..
Also like said above a fouled plug can be the culprit.
Old 08-31-2010, 03:22 PM
AChotrod's Avatar
They werent fouled car is a H/C LT1 car making over 410rwhp and showed 0 signs of issues on the dyno.
Old 08-31-2010, 07:01 PM
Carter01's Avatar
Maybe I'm over looking the obvious but could it have been your cylinders wanted a colder plug. I think I read somewhere on NGKs website that for every 100 hp over stock you need one step colder as a starting point?? I will have to go back and reread the article to be sure. So with you making 410 to the tire thats like 480ish fw. Could be wrong?
edit - from ngk website
An unaltered engine will run within the optimum operating range straight from the manufacturer, but if you make modifications such as a turbo, supercharger, increase compression, timing changes, use of alternate racing fuels, or sustained use of nitrous oxide, these can alter the plug tip temperature and may necessitate a colder plug. A rule of thumb is, one heat range colder per modification or one heat range colder for every 75–100hp you increase. In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber.
Old 08-31-2010, 07:47 PM
AChotrod's Avatar
Hmm.. That was kinda my thought^^ Think I should run a colder plug for spray??
Old 08-31-2010, 08:19 PM
LS1 SPEED's Avatar
Mike I have always had 7 in my car NA or N20 and it runs great as you know. I'm going to 8's for spray to be safe now since I might up the jet as well this weekend
Old 08-31-2010, 08:32 PM
billymz28's Avatar
LS1Tech 10 Year
Seems like mine got a little more slugish on motor when I went to n20 plugs but no prolems on the juice so I dont complain.
Old 08-31-2010, 08:42 PM
robsquikz28's Avatar
seems like your spray is up to par now huh? Your car is finally done and ready to hit the streets?
Old 09-01-2010, 09:15 AM
Torque_SS's Avatar
Lmao hahahaha so true
Old 09-01-2010, 11:37 AM
AChotrod's Avatar
Nice!!! Should be a good time this weekend!
Pretty much done. Just need to fill the bottles and get it tuned.
Old 09-01-2010, 12:22 PM
Race your car!
JL ws-6's Avatar
I laugh at all you guys bashing the autolite plugs.... better start asking around @ the race track and see what everyone is using before jumping to that conclusion.
Old 09-01-2010, 12:45 PM
AChotrod's Avatar
I agree with you. They have worked great for me in the past. I was wondering if the colder plug helped it had nothing to do with switching brands.
Old 09-01-2010, 02:14 PM
ryarbrough's Avatar
They aren't a bad plug. In my experience though, the NGK's are easier to get a read on.
Old 09-01-2010, 03:21 PM
Race your car!
JL ws-6's Avatar
I agree with that 110%. Autolite plugs are 100% harder to read. However, if you have a good handle on your tuneup, and know that everything is in good working order, they are a godo plug to run. I've found, that they are good for about twice as many hits as an NGK plug is before they need to be replaced.
You do, run the risk, if you are working a new tune up, or if you're running on the ragged edge (knowingly or not) of hurting something with them. I never tell anyone to go strait to the autolite unless it's an n/a car, in that case it's alot less of a risk, etc.
Old 09-01-2010, 03:46 PM
ATVracr's Avatar
IMO ... not many nitrous guys on this site should be running Autolites including us. LOL !
Get the strap on an NGK and you might be OK.
Get the strap on an autolite and your **** is FUCKED UP !
