new to nitrous.few q´s
Old Oct 5, 2010 | 12:16 AM
chejos13ls1's Avatar
Default new to nitrous.few q´s
what if i run c16,instead of retarding the timing..i have bolt ons,a 3800 stall and 100 wet shot....I dont plan to spray anywhere but the track,...and i go maybe 2-3 times a year ,so i dont what to mess with the pcm...but i want to be safe..is this doable?thanx
Old Oct 5, 2010 | 12:28 AM
itsslow98's Avatar
get yourself a harris speedworks interface or the lingenfelter box to pull timing just when you spray. that way you can run the best timing for your application n/a.
Old Oct 5, 2010 | 01:01 AM
that could be plan b,i was considering maybe send the pcm to tunned by frost but,that´s why im asking,for me is easier to get gas in my work....but thats just me
Old Oct 5, 2010 | 08:00 AM
ryarbrough's Avatar
Is it a bone stock tune? Are you okay with eating O2 sensors?
Old Oct 5, 2010 | 08:19 AM
yes,bolt ons...other than o2 sensors,is there any problems?
Old Oct 5, 2010 | 08:59 AM
ryarbrough's Avatar
If you've got the right plug in the car and run straight C-16 it "should" be ok (rather than possibly eating the O2's). I guess I just don't understand why you wouldn't just pull the timing (a set of new O2's is about the price of a used timing box).
Old Oct 5, 2010 | 03:39 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
On a stock tune there is no need to pull timing on pump gas. Make a pass to double check the plugs but you should be fine.
I would also not run c16 with o2's as stated. Much easier to run an ignition box.
Also just let frost know your spraying a 100 shot and you will be fine if you want to do it that way.
Old Oct 5, 2010 | 07:08 PM
thanx for the input gentlemen......q´s solved...i´ll prolly gonna stay with frost and pump gas...
