New TNT Install
Old Jan 30, 2004 | 12:37 AM
SSable's Avatar
Thumbs up New TNT Install !
Set it up and running great! pulled 525RWHP and 657TQ with a spinning clutch and only 700psi. Just bought bottle warmer and started putting in a spec 3 clutch today. Hopefully it will gain much more after I break in the clutch!
Justin
Old Jan 30, 2004 | 12:58 AM
NiceTry's Avatar
bad *** torque gains!
Old Jan 30, 2004 | 01:28 AM
Black02SS's Avatar
Got a copy of your dyno? What shot was that?
Old Jan 30, 2004 | 03:34 AM
Gimp98TNT's Avatar
Sweet job on the install! I like the way you mounted the solnoids, did you make that bracket?
Old Jan 30, 2004 | 03:40 AM
Assassin's Avatar
damn, link didnt work for me
Old Jan 30, 2004 | 07:06 AM
Fast SS on TNT's Avatar
Thats what the new bracket looks like from TNT. Though its not very new. I got mine like that two years ago.
Old Jan 30, 2004 | 07:16 AM
Cummins's Avatar
Very Nice
Old Jan 30, 2004 | 10:43 AM
Turo's Avatar
wow, impressive torque gain! how much are you spraying?
Old Jan 30, 2004 | 11:57 AM
SSable's Avatar
I have a Dyno sheet with the first run on it but not the last. I will get the final after the cluch install. Just a 100 shot with H/C.
Justin
Old Jan 30, 2004 | 12:03 PM
SSable's Avatar
Thanks Gimp98TNT, I used the supplied bracket and painted it black. this setup made for easy strait-forward wiring to the MSD and relays.
Justin
Old Jan 30, 2004 | 01:28 PM
mike02ss's Avatar
Hey SSable did you do any fuel system upgrades? Thanks. Thinking about a similar set up.
Old Jan 30, 2004 | 03:00 PM
SSable's Avatar
I have a electric fuel pressure gauge that tells all. I am consistantly ranging from 57.5 - 60 psi. when I spray i did not see it dip below it's normal position, but it was hard to tell going so damn fast!!! from what I have seen a 100 shot will be fine with stock pump, any higher I would consider a new pump.
Justin
Old Jan 30, 2004 | 03:10 PM
maddboost's Avatar
So the power ring clamps to the TB? My buddy had a TNT kit 2 years ago and it didnt attach to the TB but rather he used a smooth bellows type piece cut to fit the ring. It was kind of a hack job but it worked. I see you have a line lock too. I love mine it makes burnouts so much easier at the track.
Old Jan 30, 2004 | 05:49 PM
SSable's Avatar
Yes, It attaches the TB and is secure. As for the line lock... Need all the traction I can get!
Justin
Old Jan 31, 2004 | 01:53 PM
stangkillin99ss's Avatar
looks great i just purchased a TNT kit myself only problem is my lid gets pushed ahead about 1.5 inches? how did you get yours secure? thanks
Old Jan 31, 2004 | 01:56 PM
Black02SS's Avatar
I used a fernco bellow and cut it to fit the ring. I had the same problem as you did and that fixed it for me.
P.S. You need to learn how to drive.
Old Jan 31, 2004 | 02:18 PM
maddboost's Avatar
Gotta love the Fernco bellow $5 and its just as good if not better than the SLP $50 bellow.
Old Jan 31, 2004 | 03:15 PM
busted
gonna try the fernco!
