hiding nitrous intake line?
ive decided next im going nitrous, dry kit. i have a k&n cold air intake, which runs down behind my fog light, under the fuse box area there is a rubber plugged hole.
my idea was to drill a hole in that rubber plug, run the dry nitrous line through that hole, run it up to about 6 inches before maf where i heard its supposed to be. from my understanding this would work, tell me if im wrong.
i was thinking just a small custom bracket. and just so i dont blow my motor, 75 dry shot shouldnt do any harm unless somethings already wrong right?
I wouldn't want any brackets inside the intake tube. You've also got a 3.8 (from looking at your sig) a 75 hit on that is going to be different than a 75 hit on a ls1. I'd start low and work your way up, checking the tune as you go.
Fullthrottlev6.com will be a good resource for you.
Nitro daves stuff is about 2/3's the way down the page.
http://www.nitrousoutlet.com/catalog...=23§ion=88
